FTAO MegaSquirt Users Please!
#42
Tried two differnet laptops (one USB to RS232 converter, the other a genuine RS232 port), and no the lights do not flash.
All that happens now is the centre LED comes on and stays on, whereas before I tried to re-flash it would just flicker on once when the ignition was turned on.
#44
Karlos try msefi forum if you cant sort that problem.
I am really not so good with ms-efi internals, luckily never had any problems with board itself. I replaced that iact driver transistor and all went fine. You dont have stimulator board? Can you take your ecu off and take it to someone who has stimulator and try to "debug" the problem.
#45
Sorted!!! Had to use the Boot Jumper to reflash the Eprom now all is well!!
Why it needed flashing I dont know?? Is it common for these to get corrupted??? Dont fancy being out somewhere and all of a sudden my ECU bums out on me??!!!
![](http://i413.photobucket.com/albums/pp217/Th3blueroom/bootloader.gif)
JK12
33
26-04-2021 12:09 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
