s2 overheating
Old Aug 12, 2009 | 06:35 PM
markparker73's Avatar
markparker73
Enthusiast
Default s2 overheating
hello, does anyone else's series 2 escort rs turbo overheat in traffic? mine does it all the time an is realli startin to annoy me now! iv had all the cooling side of things checked an theres no problem there...i no its an old car an they do it alot but does anyone no any good ways of how to keep it cooler? iv got twin fans and a big ally rad already!!
ideas anyone? thanx
Old Aug 12, 2009 | 07:20 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
82° Thermostat would be another thing to try. Makes a bit of a difference.
Old Aug 12, 2009 | 08:25 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
Mine used to run warm in traffic. There was air in cooling system! Also i've changed the thermostat with a 82 C and put 2 fans on the rad. Now temm in traffic is between the ''n'' and ''o'' (on the gauge). And here temperatures are 35-40 C now.....
Old Aug 15, 2009 | 04:50 PM
markparker73
Enthusiast
what does an 82c thermostat do to help??
Old Aug 15, 2009 | 04:55 PM
tasos77's Avatar
tasos77
opening earlier....
Old Aug 17, 2009 | 09:25 PM
RSmark84's Avatar
RSmark84
if it gets too hot, turn the heater on full wack.
the temps will drop right down. it'll be hot inside for a while, but turn it off when your moving again.
Old Aug 17, 2009 | 09:27 PM
martinmilne's Avatar
martinmilne
i know it does help but why wat does it do
Old Aug 18, 2009 | 07:03 AM
Karlos G's Avatar
Karlos G
Balls Deep!
The heater matrix is like a small rad, so it's like turning another cooling fan on!
82 degree thermo lets the water pass through the rad earlier starting to cool the water before it gets as hot as as standard thermo (90 degrees IIRC).
Old Aug 19, 2009 | 05:03 PM
martinmilne
mines started gettin hot on motorway driving ??? but fine in town and traffic is not to bad everything checked as normal and replaced all that i can think of is rad now ! how do i check to see if it is the rad cos water is circulating
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Ade
Feb 8, 2007 05:11 PM
kurdt5
Jul 17, 2006 03:01 PM
fiestaturbo1984
Feb 19, 2006 03:51 PM
woodz77
13
Nov 6, 2005 03:02 PM
