Escort mk4 xr3i efi
Do you know if there is a step by step guide how to convert to fiesta rst?
its not all as simple as that tho mate
u will need and oil return strenthened bottom end lsd brakes exhaust turbo the efi loom is easy u just unplug the old loom and add the new one it all unplugs easy job but its more the hardware things u need you would be better just buying a frs and dropping the engine in ur xr3 personally id go better and 2ltr zetec turbo it
u will need and oil return strenthened bottom end lsd brakes exhaust turbo the efi loom is easy u just unplug the old loom and add the new one it all unplugs easy job but its more the hardware things u need you would be better just buying a frs and dropping the engine in ur xr3 personally id go better and 2ltr zetec turbo it![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
buying, conversions, ecu, efi, engine, escort, ford, guide, httpwwwxr3ur, megasquirt, mk4, things, turbo, xr3, xr3i
