smokey joe
Old 08-08-2009 | 11:31 AM
ste45's Avatar
ste45
Default smokey joe
my escort decided to start smoking , it puffs blue smoke when am changing gear when giving it some ... took my boost pipes of yesterday to check for play in the turbo it has a litle side to side but no in or out , also noticed that my pipes had loads of oil in them so traced it all the way back to the throtle body ( which also had oil in it ) , so i cleaned them all out , then this morning i drove it about 7 miles came back ome and the pipes were full of oil agen ( even had a puddle of it in the bottom of my charge pipe) ... any1 know what my problem is ? cheers
Old 08-08-2009 | 11:45 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Turbo oil seal mate, or your engine is breathing loads of oil into the metering unit.
Old 08-08-2009 | 11:47 AM
liam-rst's Avatar
liam-rst
shit happens
+1
Old 08-08-2009 | 11:56 AM
ste45's Avatar
ste45
can the oil seal be changed or is it new turbo time ?
Old 08-08-2009 | 12:35 PM
jonny s2's Avatar
jonny s2
you can get kits but id say its a pro job,you dont really want to start messing with turbos,probably end up costing more if you mess up
turbojoe69
17-09-2015 07:07 AM
Steve Cooper
15-09-2015 04:39 PM
turbojoe69
18-08-2015 06:41 AM
Adam-M
22
10-08-2015 10:46 AM
escortrsmatt
13-07-2005 08:28 PM
Quick Reply: smokey joe
