single pass and double pass intercooler what is the difference
The posh are up!!!
as above i know about single pass, but what is the difference between the single and a twin or double whatever there called?
You loose more of your boost pressure with a double pass but the air is colder,depending on size, but with single pass pressure is retained but not cooled as much again depending on size.
focus rs 1672
not always,t28 rst had a single pass AVA cooler with inlet and outlet on same side,not full front mount but bigger than a double capacity,top cooler
Fleet Manager
not alwats 1 side of the other thats the best way to make it but airtec makes a singel pass unit both exits on 1 sode very good they are to air dosn't have to doubel back on its self as with twin pass
YES I KNOW I CANT SPELL
loosely speaking within the twin pass cooler the boost has to traval through the bottom half of the cooler through one of the end tanks then back through the top half of the cooler hence the term "twin pass"
where a single pass cooler the boost goes from the bottom to the top or from left to right (like rs500 coolers) and only has to travle through the cooler once.
focus rs 1672
im sorry but the only way IMO you are going to loose boost pressure is if you have a leak.
u get a pressure drop with twin pass
focus rs 1672
SMILER258
28-09-2015 09:04 AM
Russ Payne
25-09-2015 08:29 PM
