starter motor problem
Old Jul 20, 2009 | 08:01 PM
juffer's Avatar
juffer
Default starter motor problem
I have finaly got around to starting the engine but the car won't crank over. You can hear the dog coming out to ingage the flywheel but it just makes 1 click. I gave it a smack with the hammer but no luck. I found a spare one and changed it over to see if that worked but still no luck? Its a 1600 cvh.
Do you think it could be bad earth?
Im using a efi flywheel is it different starter?
Old Jul 20, 2009 | 08:05 PM
adduk's Avatar
adduk
yeah id check to see if the main ground is connected to the block first, ensure it has a good contact at both ends then go from there.
Old Jul 20, 2009 | 08:12 PM
juffer's Avatar
juffer
The big earth to the gearbox back to the battery is on and tight and that is also connected to the body. i have also got another from the gearbox to the body. Its very strange.Also forgot to mention That it has a full battery aswell. Its sounds like it has a flat battery and only has the power to just tickle the dog gear across lol.
Old Jul 20, 2009 | 08:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Try bridging the solenoid to the live on the starter it should turn over.
Old Jul 20, 2009 | 08:18 PM
juffer's Avatar
juffer
i will give it ago.
Old Jul 20, 2009 | 08:22 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Oh BTW the FINIS code for the FRST throttle cable is in my thread for you.
Old Jul 20, 2009 | 09:09 PM
juffer's Avatar
juffer
cheers karlos for the help.
Old Jul 20, 2009 | 09:57 PM
OLDSKOOLRYAN's Avatar
OLDSKOOLRYAN
i had this problem, ensure the contacts are mint, clean them up with sand paper and that the large contact to the starter goes on FIRST then the small one on top.
Old Jul 21, 2009 | 12:33 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as above, very common for the terminals to get shit up and stop engine cranking over.
Old Jul 21, 2009 | 12:46 AM
Grandad racer's Avatar
Grandad racer
silly question,but is your battery flat?
Old Jul 21, 2009 | 08:09 AM
Karlos G's Avatar
Karlos G
Balls Deep!
cossie362
Oct 11, 2015 03:53 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
