help needed
Old Jul 20, 2009 | 11:50 AM
rst cabbie's Avatar
rst cabbie
gingeRS cabriolet
Default help needed
since my last posts ive now found my map sensor to be at fault . im running a efi ofab set up with a 195 power chip and beiges with a 2 bar map sensor . ive just orded a escort cosworth 2.5 bar is a case of just plugging it in or does it need mapping to my chip and ecu
Old Jul 20, 2009 | 07:00 PM
rst cabbie's Avatar
rst cabbie
gingeRS cabriolet
bttt
Old Jul 20, 2009 | 07:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes IIRC you will need the correct chip to run it, your current map will still 'think' it's a 2 bar sensor and your fuelling/timing will be wrong!
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
