power steering
Old 07-07-2009 | 08:26 PM
crazycage's Avatar
crazycage
Default power steering
anyone put power steering on a rst?? if so how did they do it what did they use?
Old 07-07-2009 | 08:29 PM
jammerrs's Avatar
jammerrs
alot of people use corsa b units, no idea if this works on rsts but older fords use them and lots of other cars aswell
Old 07-07-2009 | 09:11 PM
mikemcc03's Avatar
mikemcc03
does anyone know how the electric powersteering works?
Old 07-07-2009 | 09:13 PM
darrenb16two's Avatar
darrenb16two
power steerings for girls! Get a fiat punto with city steering mate
Old 07-07-2009 | 10:07 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Old 09-07-2009 | 12:55 PM
Oranoco's Avatar
Oranoco
I've never found my RST steering all that heavy even after jumping out of my daily hack that has it. I find the brake servo needs far more getting used to
Old 09-07-2009 | 01:10 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
as above
Old 09-07-2009 | 01:37 PM
crazycage's Avatar
crazycage
Originally Posted by Zetec_mk4_XR3i
as above
What about on track with realy fat slick tyres. I think it would be much better
Old 09-07-2009 | 02:02 PM
Christian and Beccy
#1 in Spelling Club
On track with fat slick tyres, I'd be more worried about your welded driveshafts TBH.
Old 09-07-2009 | 02:19 PM
Micky's Avatar
Micky
The passenger side hub will break before youre arms do.Powersteering on a RST is only for girls!!Regards,Micky
Old 09-07-2009 | 02:24 PM
darrenb16two
Got to be honest, ive not heard of many race cars with power steering mate. Its uses engine power to run the pump so if the car had it originally its usually removed
Old 09-07-2009 | 02:49 PM
crazycage's Avatar
crazycage
No need to worrie mate just because you cant weld for shit doesnt mean i cant. And its not for my car ive got a frst.
the escort rst shafts are welded from fords.
if you want to put your car up against mine on any track or strip just name and let the times do the talking. the only one you will win is top speed as its not my thing but 0-60 0-100 1/4mile or round a track any time anywhere just name it
Old 09-07-2009 | 09:16 PM
project rs's Avatar
project rs
sounds like we've got a good race on the way between these 2 cars but as is normally the way something will happen to one at the last minute
Old 09-07-2009 | 09:56 PM
crazycage's Avatar
crazycage
TBH it will never happen and no one has anything to prove anyway .ill still be fitting power steering to a escort as my mate wants it and its his car.
Old 09-07-2009 | 10:04 PM
tomo1976's Avatar
tomo1976
the mk 5 escort with the 1.4 cvh has pwr steering my mate made that fit on his with a little work but dose the job
Old 10-07-2009 | 06:41 AM
JesseT's Avatar
JesseT
Do a search, this has been discussed only soooo many times.
The standard steering is not heavy at all, but it's really slow with the amount of turns lock to lock. After fitting a quick rack, it will become heavy. A power steering usually takes care of both problems at the same time.
Old 10-07-2009 | 08:51 AM
Rick's Avatar
Rick
Jesse has nailed it.
As std, it's not that heavy, especially when you're moving. The problem is it's so slooow. It feels more like steering a boat than a hot hatch. Putting a quick rack on solves this, but then it really does become heavy, making manouvering nearly impossible. My gf struggles as it is when i run 215 tyres.
Forget about hydraulic power steering, it's old fashioned. Race cars defo don't use it, but they do use electric power steering which assists the column. Here you don't have any engine pumping losses, and have full control over the amount of assistance. Andy G runs this on his Focus as well as countless others.
Rick.
Old 10-07-2009 | 09:14 AM
Zetecfiesta's Avatar
Zetecfiesta
corsa power steering pump fitted to the escort steering column need to use the corsa PS ecu and a sensor to monitor how fast the car is travelling plus need to cut and weld the steering column.
Old 11-07-2009 | 03:11 AM
Micky's Avatar
Micky
I see strains of the internet "Big Up" plus a huge pinch of "Taking banter too seriously" in this post!!! Regards,Micky
Old 11-07-2009 | 07:42 AM
crazycage's Avatar
crazycage
very true long hard day.
Old 12-07-2009 | 05:07 PM
Rick's Avatar
Rick
Old 08-10-2009 | 12:50 PM
Dennis_Wiseman's Avatar
Dennis_Wiseman
Driving on the road is fine. Its parking where its a nightmare especially if your quite boxed in.
Car would be so much nicer to drive with P/S imo.
Will the Mk5 CVH Escort steering be a straight swap over ?
Old 08-10-2009 | 01:24 PM
JesseT's Avatar
JesseT
It will definately not be a straigth swap as the rack is totally different. Rod ends are of different size, the rack is longer from joint to joint, the mounting is diffrerent, and the splines are of diffeent standard for the steering column.
I have my conversion now finished and it's working nicely. Mondeo 2.0 Zetec turbo engine with mk6 zetec Escort PAS pump and reservoir joined with a 1987 US-Escort rack.
Old 08-10-2009 | 03:30 PM
orionmojo's Avatar
orionmojo
If you could find a popemobile mk4 van, they had power steering. you used to see them with wheelchair lifts on mostly
Old 08-10-2009 | 03:45 PM
dangerousbrian's Avatar
dangerousbrian
i know a lad who has a mk4 cabby with power steering..its genuine ford stuff fitted at the dealers as the car was originally a motability car..i wanted to buy it off him until i tried it..there wasnt a lot in it..the gains dont justify the cost or chew on fitting it imo..maybe electric pas may be better..i fitted a new standard rack and the steering is much lighter..prob a knackered rack is the most common cause of heavy steering
Old 08-10-2009 | 04:35 PM
crazycage's Avatar
crazycage
this conversion was done at the time i started the tread and the lad i did it for is over the moon with it .
Old 08-10-2009 | 05:01 PM
jonny s2's Avatar
jonny s2
did you do it the electric power corsa route
Old 08-10-2009 | 05:11 PM
crazycage's Avatar
crazycage
yes ,and i had it done before i asked how anyone else done it lol.
Old 08-10-2009 | 05:15 PM
jonny s2's Avatar
jonny s2
was it easy and what parts were neede and involved? would you rate doing it?
Old 08-10-2009 | 05:18 PM
project rs's Avatar
project rs
believe this electric route is way forward but need to find a slightly smaller pump than the corsa one so don't have to cut too much dash out
Old 08-10-2009 | 05:20 PM
jonny s2's Avatar
jonny s2
i know quite a while back guys were putting them on old skoolers
Old 08-10-2009 | 05:26 PM
crazycage's Avatar
crazycage
smaller motor you mean?? there is no pumps lol.
Old 08-10-2009 | 05:29 PM
jonny s2's Avatar
jonny s2
its got to be a great conversion anyway for those who drive these cars daily with tight parking spaces
Old 08-10-2009 | 05:31 PM
crazycage's Avatar
crazycage
i wouldnt say it was that hard to do!! but its for girls and a waste of time,get a punto with city steering if thats your thing , just some of the shit that was thrown my way when i asked about it lol
Old 08-10-2009 | 05:32 PM
project rs's Avatar
project rs
i stand corrected
Old 08-10-2009 | 06:14 PM
jonny s2's Avatar
jonny s2
if i were to use every day i may have considered it,but as im building a fast road track car its prob not for that as you can feel the road more with the rst steering,just a bit heavy under tight parking spaces
Old 08-10-2009 | 06:50 PM
Rick's Avatar
Rick
there is no assistance when moving, it just works at parking speeds. It has a torque sensor which detects how hard you are turning the wheel. at speed as you never have to turn the wheel hard, it doesn't offer any assistance. At parking speeds it gives as much assistance as necessary to stop it becoming heavy, which is why it's so good on track cars. It really is properly impressive.
Rick
Old 08-10-2009 | 09:07 PM
barnard's Avatar
barnard
i saw this done to a grey escort rs pickup the other day
Old 09-10-2009 | 10:41 AM
RSTurboSI's Avatar
RSTurboSI
im laughing at you not at the comment.
If you read into it more, the cars up for braking, and TBF i couldnt see you beating him.
Good luck on that pal.
Regards the PS, It wouldnt be the same tho, its a classic car with no Power Steering to Feal the road more, its what owning a car is all about.
Old 09-10-2009 | 05:00 PM
crazycage's Avatar
crazycage
why couldnt i ??? you dont no me or my car !! and i dont need any luck from you to do what i said thats for sure.
Quick Reply: power steering
