Rear disc coversion problem!?
Old Jun 7, 2009 | 05:46 PM
Matt-Turbo's Avatar
Matt-Turbo
Question Rear disc coversion problem!?
Yo guys have rear disc coversion done and when i brake heavliey it brakes more on one side? Any ideas? Cause it near pulls the car acoss the road.
Old Jun 7, 2009 | 10:26 PM
Matt-Turbo's Avatar
Matt-Turbo
Any ideas guys?
Old Jun 8, 2009 | 07:17 AM
mentalasanything's Avatar
mentalasanything
Could be several things. Most likely to be the load compensator valve on that particular side, swap it out or bypass them both (get a pipe made up) and see if it's any better. If not it could be a sticky caliper.
Lee
Old Jun 8, 2009 | 05:53 PM
Matt-Turbo's Avatar
Matt-Turbo
Thanks man i think il by pass them both. It give you 50 50 braking think it will be a good job wat you think?
Old Jun 9, 2009 | 09:29 PM
mentalasanything
It won't change the bias front to rear. The load compensators just reduce the pressure to the rear calipers/drums based on how far the rear has lifted under braking.
If you then start to see over breaking on the rear (Usually only if you have std RST fronts and a disk conversion on the back) you will have to go down the bias valve route, but this means re-plumbing the system.
Lee
Old Jun 9, 2009 | 09:37 PM
morph's Avatar
morph
REAR disc conversions on rst's are a aload of crap! i have it on my car, not my choice came with car and when braking hard the back end starts to snap! i used willwood brake bias valves to sort it out, would have been easy sticking with drums!
Old Jun 9, 2009 | 09:44 PM
Matt-Turbo's Avatar
Matt-Turbo
Yeah man i heard that but i got them on it when i got it were did you get them at man?
Old Jun 9, 2009 | 09:47 PM
Matt-Turbo's Avatar
Matt-Turbo
Lee
I have full cossy coversion done so it should be sweet if i just bypass them?
Old Jun 10, 2009 | 06:19 AM
Pat's Avatar
Pat
I run discs all round on mine but with cossie 4 pots on front i aint had any probs with mine.. must be a lucky one..
Old Jun 10, 2009 | 06:25 AM
JesseT's Avatar
JesseT
I've always wondered, why people always fit the bigger of the two Sierra rear disc sizes and then complain about overbraking in the rear.
Old Jun 10, 2009 | 12:37 PM
S2Dan's Avatar
S2Dan
Get rid of the rear compensators, and just run a fixed pressure to the rears via a bias valve. Then that will eliminate the question of faulty compensators.
Defiantly check the calipers, could well have one that is sticky. Worth checking as you don’t want to take chances when the breaks are involved.
But dont be put off by the haters, if its done correctly and tackfully, the rear disk conversation on S2 works very well. Also think about the brakes at the front, it will help if you go for some bigger stuff, or imo cossie stuff as a minimum with rear disks.
Good luck mate.
Old Jun 10, 2009 | 12:49 PM
mentalasanything
Good luck mate.
Hear hear! It is only a problem when rear disks are used with std fronts, as this alters the bias.
Lee
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
james kiely
Aug 28, 2015 08:58 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
