s2 efi running problems
Old May 24, 2009 | 01:06 PM
paul66 turbo's Avatar
paul66 turbo
Default s2 efi running problems
ive got a s2 running efi using ofab the loom is from a xr3i efi ive fitted it to my s2 and done the pin changes at the ecu fitted an frst air temp sensor and cut wire 2 at the edis, its got a 165 superchip and beige injectors.
the problem ive got is when it starts it runs like a bag of $h!t missfireing and chugging its fueling up massively smoking black and grey smoke it stinks of fuel dont no what to do, it was doing the same when it was running as an ofac setup if i disconected the map sensor it would idle and rev but now it just dies
any help will be great
Old May 27, 2009 | 11:48 AM
Chris69's Avatar
Chris69
you need to get the fueling setup at a tuners mate it sounds like the fueling is well out.
for a start you need to put the standard injectors back in to suit the 165 chip or buy a 195 chip to suit the beiges.
Old May 27, 2009 | 01:15 PM
Rab's Avatar
Rab
Fucking superstar........
165 chip? and beiges? correct me if I'm wrong but was the '165' chip written for the std injectors??
Old May 27, 2009 | 01:19 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah i think it was (blues) which means the chip will be holding them open too long for beiges hence the overfuelling.
Old May 27, 2009 | 09:00 PM
Rab's Avatar
Rab
Aye, not going to run right is it STD injectors are cheap as chips Get some and see if that cures your issue
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 19, 2015 11:46 AM
marky_g
Aug 17, 2015 12:21 PM
Zoggon
Aug 10, 2015 10:39 AM
