local help!
Old May 20, 2009 | 07:55 PM
mike s2 rst's Avatar
mike s2 rst
Question local help!
hi, does anyone know anyone in the guildford / woking area who might be up for looking at my rst???everyone i have tried seems to run and hide!!!!
Old May 20, 2009 | 08:31 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
What's up with it? detailed explanation and you might get help here!
Old May 21, 2009 | 07:24 PM
mike s2 rst
was overfueling like mad so i thought it was a problem with the metering unit thingy!!iv never seen or played with these so i wanted someone to take a look but since then it started misfiring badly!so i carried out some checks and found i had fuel in the sump and am loosing pressure on cylinders 1,3 and 4!!!!!so iv just ripped the head off and found some bright spark who rebuilt the engine just before i bought it didnt grind the valves in and fitted the wrong piston rings!!!!!!!!!!!!!!!!!!!!!!so now im going to start the rebuild !!!with some nice new shiny bits!!!might even go for efi due to what people are saying about metering heads!!
Old May 21, 2009 | 07:28 PM
white2lsr's Avatar
white2lsr
How can you tell the rings are wrong just by taking the head off??
Old May 21, 2009 | 07:31 PM
mike s2 rst
pistons are out!!!!!!!!!!!!!
Old May 21, 2009 | 08:04 PM
Karlos G's Avatar
Karlos G
Balls Deep!
What a nightmare!!!
Old May 21, 2009 | 09:16 PM
mike s2 rst
yea i no!!knew it was to good to b true!still i was planning on a major rebuild just not this quick!!!!
Old May 22, 2009 | 10:14 PM
mike s2 rst
iv been looking into efi and i have no idea what to go for!been looking through previous threads and it just ends in a list of confusing letters!!!!lol!!!!i was guna fit it myself coz it dont seem to much bother but i am thinking it would be worth getting some advise and maybe even getting someone to fit it for me!iv been searching and found i live between abc motorsports and torque of the devil just wondered if anyone would recomend either?this is my first blue oval so im treading new water!!!if not twin 50 webbers it is!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 23, 2009 | 12:21 AM
botters's Avatar
botters
competant bodger
your best bet for the money is cosworth managment on the standard mfi manifold as this flows just as well as an efi manifold except there is less parts to change! but you will need an adapter plate between manifold and head for the injectors and/or head mods to the ports for the injectors to spray through but saying that mfi is good for arond 250-300bhp with a 5th injector ive had no problems myself with mfi and my car was used for daily duties till the gearbox broke AGAIN!!!!!!
Old May 24, 2009 | 07:47 AM
Roger The Dodger's Avatar
Roger The Dodger
cosworth managment is not good value for money not .. the parts are old and exspensive.
My advice is go for gotech as it is a proper stand alone system and new .. Ie no doggy old looms etc .
As for fitting it you have Enhanced Performance at gatwick with years of rs behined them or Jam sport in northampton again with years in the no...
Enhanced Performance 01293 560 291 Jam sport 01604 755529.
good luck . ps both will supply or supply and fit ..
Oranoco
12
Oct 2, 2015 02:18 PM
Kam B
Sep 30, 2015 01:32 PM
IainRS1700T
Sep 25, 2015 06:44 AM
krypton
Sep 23, 2015 07:29 PM
