wobble!!!!!
Old May 17, 2009 | 04:26 PM
Chopshop85's Avatar
Chopshop85
Default wobble!!!!!
Just got back from a blat out in the scort and it has developed huge ammount of wobble under breaking. has always been slightly wobbly but its got crazy
light or heavy breaking , doesnt matter so long as its faster than 50mph??? tried slaming the anchors at 70 and it threw the wheel out of my hands it was that bad?? :s
im thinking warped discs purhaps? anyone think of anything else it may be?
Old May 17, 2009 | 04:27 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
normally its just the disks bud
Old May 17, 2009 | 04:46 PM
Chopshop85's Avatar
Chopshop85
yeah i thought that might be the case, i just wasnt sure if there was anything that can cause it. I guess these mk4 escorts are pretty simple tho!
cheers
Old May 19, 2009 | 12:52 AM
Grandad racer's Avatar
Grandad racer
cheack your rear wheel bearings are not loose, belieave me if they are you will get all the front end problems you are having, i know iv been there, changed every thing under the front, cost a fortune, in the end it was a loose rear wheel bearing, unbelieavable!!
Old May 19, 2009 | 09:23 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Thats actually a really good point, I had the same thing! Just needed adjusting up a bit
Old May 19, 2009 | 09:44 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
as above check bearings and if not replace discs 10 minute job
Old May 19, 2009 | 11:43 AM
white2lsr's Avatar
white2lsr
If your discs are warped then any vibration will be amplified through the steering column if there is any wear in the bearings/bushes.
Mark Mawson
Aug 31, 2015 07:09 PM
Alloy wheels and ICE for sale
Aug 16, 2015 07:55 AM
fatboy billy
Aug 3, 2015 08:34 AM
JohnP001
Ford Escort RS Cosworth
18
Nov 19, 2006 10:54 AM
sammi-jo
Jul 29, 2005 02:40 PM
