Indicators not working after loom swap
Back In The RS Game!
Hi, ive swapped my xr3i loom in my cab for a s2 erst loom and s2 engine. All works, however i cant get the indicators to work. Ive checked tehc onnections and fuses and they are ok. The only thing i can find is a relay missing from the lhs of the fusebox as you are looking at it. Is this to do with the indicators? If not then what else could it be?
the relay for the indicators is under the ignition cowling iirc. its under the hazard switch. and other than that theres an earth you've missed. theres one each for the side (wing) repeaters, and one each where the loom breaks out for the headligha ans indicator wiring. make sure you havent missed one either side and there making good contact.
so am i missing a relay in the fusebox as well? Thanks for the suggestions. I know the side repeaters and rear indicators are earthed up as done them myself. Theres not even no ticking noise or indicators lights on dash.
JoeyBoyden
04-01-2024 02:36 PM
muz
16-08-2015 12:57 PM
RIB1122
12-08-2015 08:51 PM
