rs turbo engine builders who do i use any ideas?
a 300bhp zetec turbo engine fully built is Ł3200 for the silver top and Ł3450 for the black top
the engine spec is ;
custom forged pistons and rings
h beam rods
new gaskets
upgrade wrist pins
multi layer headgasket
oil pump
water pump
big end and mains bearings
jockey wheels
timing gear
timing belt
sump with oil return
headbolts
area six camshaft profiles
area six valve springs
hydralic followers
painted cam cover
engine breather relocated (if requested)
plugs and leads
AND BEST OF ALL 12 MONTHS WARRANTY
THIS IS THE SAME BOTTOM END THAT IAM RUNNING ON MY DYNO PROVEN 522 BHP ZETEC TURBO ENGINE. I JUST ADDED BIG VALVE HEAD , CAMS, T61 TURBO, CUSTOM INLET , CUSTOM EXHAUST MANIFOLD
SO YOU GOT PLENTY BHP TO COME , THATS IF YOU WANT IT
HOPE THIS HELPS
P.S TELL HIM PAUL CHESHIRE PUT YOU IN CONTACT
IAN HOWELL TEL ;01522 877887 AFTER 6 (HES GOT KIDS)
big_Rad
15-09-2017 09:36 AM
big, builders, end, engine, go, good, motorcycle, oval, round, rs, shells, so last year, turbo, turbocharged, vw
