efi running problems
Old Feb 15, 2009 | 09:30 PM
paul66 turbo's Avatar
paul66 turbo
Default efi running problems
ive got a s2 running efi using the xr3i ofac loom ect, the problem is the car wont run properly when the map sensor is conected, ive cut the no 2 wire at the edis and fitted a frst ofac map sensor but just miss fires when its conected?????????????
Old Feb 15, 2009 | 09:33 PM
stembo21's Avatar
stembo21
wrong map sensor i think as it happend to my car
Old Feb 15, 2009 | 09:42 PM
paul66 turbo
Default rs parts
hi mate i brought a frst ofac map sensor off here but maybe it could be faulty??
Old Feb 15, 2009 | 10:24 PM
stembo21's Avatar
stembo21
you need to find out if it is defo off a frst whats it shaped like
any pics
Old Feb 15, 2009 | 11:22 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
mate just had this problem with his onion turbo,run like shite with the map connected thn when u took it off it was ok, the map was a std fezzie one
i would say tht is ur problem!
Old Feb 17, 2009 | 08:32 AM
orion88's Avatar
orion88
i thought the map sensor and ecu were in pairs so u cudnt run a map sensor from an unmatched ecu?
Old Feb 17, 2009 | 07:03 PM
paul66 turbo
Default rs parts
thanks chaps going to try another map sensor anybody got an ofac sensor??
im nt sure if it needs to be matched to the ecu mate i thought as long as its ofac and nt ofab it will work??
Old Feb 17, 2009 | 07:25 PM
Danster76's Avatar
Danster76
Out of interest, how big is your miss fire? Engine shaker, trying to stall?
Old Feb 17, 2009 | 07:29 PM
paul66 turbo
Default rs parts
it will sit there idleing but like its running on three cylinders and then when you rev it she cuts out mate
Old Feb 17, 2009 | 07:34 PM
Danster76's Avatar
Danster76
Are you local? I have an ofac map you could try out
Old Feb 17, 2009 | 08:06 PM
paul66 turbo
Default rs parts
no mate im about 3 hours from you. do you want to sell it?
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 19, 2015 11:46 AM
marky_g
Aug 17, 2015 12:21 PM
Zoggon
Aug 10, 2015 10:39 AM
