st170 bottom end
st170 bottom end
hey guys is a st170 bottom end any good for a zvh, wat boost will standard pistons take or do i need replacements? wat other modifications if any will i need to do?
2.0 zetec turbo
hey guys ive bought a zetec engine and was wondering wat parts i need to buy? wat wiring and ecu do i need? inlet, turbo manifold etc???
thanks
thanks
are you using the st170 head aswell?,anyone know if they any good for around 300bhp. i thought the block is the same as a zetec but with different internals
st170 bottom end
hello guys as ive said ive bought a complete st170 bottom end. and ive had an offer of a normal black top zetec head. will these two fit together ok? i was just wondering if i would need to change any of the spec of the head to run a t3 turbo. ive got a inlet manifold off a rover 620 ti which i think fits and will be ok.
thanks
thanks
With regards to ECU I would find a tuner you trust to map your car and take the advise they have to offer, OMEX, Pectel, Webber, Megasquirt would all be capable of fuelling your car
I would personally change the pistons and rods so that they were not a worry, I would rather know something is strong enough than think or hope that it is
I would not personally take the route of the rover inlet im yet to be convinced of its attributes
You will also have to make mounts for and consider your gearbox options
Colossal Pervert
The reality is if you have no idea of what you're doing you are not going to get all the answers from the internet/forums on how to build a high performance engine and it be successful.
Balls Deep!
But generally after enough thrashing about between members the right information will come out!
SMILER258
28-09-2015 09:04 AM
DavidK
27-09-2015 02:55 PM
