Fitting rs clocks in base spec mk4
I will soon be fitting some rs turbo clocks into my base spec mk4 escort, i was wondering how id go about wiring up the rev counter?the car has a 2 litre zetec engine fitted and will be running on the standard ignition system.
yes mate,im running bike carbs so its just the same ignition system as the standard 1.3 hcs,coil pack and a carb! At the moment iv got the speedo and the clock on the lft handside.
assuming we talking as if the clocks were to be fitted to a 1.3 ohv engined base spec, the rs rev counter wont work, even with the link to the coil, it will over-read terribly.
from memory havin read up on doing it on mine years ago, its either a massive wiring job, or judgin by a similar thread in the technical room, u need to source the clocks from a 1.3 eclipse model
alright mate its ross here
prev comment was right - you ideally need to source Eclipse clocks, dont ask me why, must be summat to do with them being used with the 1.3 ignition system - i found this out by accident years ago and used them ever since - drying up a bit now though
cheers guys
could you explain where i would put the wire from the coil to the clocks?i know that when you fit the zetec engine in a mk2 fiesta and run the esc moduel you can adjust the way the rev counter to suite or wire in some diodes
cheers
cheers
orion=mini saff
was told the 1.3 stuff dont run to well on a zetec?
its pretty easy to wire in,easiest way is to get some clocks plus the blue and white connectors,u can transfer wire for wire,thn run a wire for rev counter,
cheers for that mate
so i need to get the connectors that go to the back of the clocks from an rs turbo loom?
A friend of mine has the same setup in a xr2 and the rev counter reads half the actual revs but the revcounter can be adjusted so il give it a go!
steerfromdarear
28
29-01-2016 06:14 PM
