s2 heated rear screen problem
basiclly my heated rear screen don't work in my s2. You can press the buttom which lights up and goes out afterwards but it does not clear any lines at all.
is there a way to test for power at the back?
I'm not to sure how to check it on my car.
cheers folks
cheers folks
if the light comes on you will have power...your screen will be fooked...try a continuity test on the glass via both terminals..chances are the glass is the original and just "broke" like other car parts
I had same problem with mine,check the wires are in tacked in the rubber gromet that has the wires in on tailgate(top corner) as mine had snap.
Pretty confident it will be broken wires between the body and the tailgate.
09-10-2015 07:38 PM
siscossie
27-08-2015 09:27 PM
track.focus'd
12-08-2015 05:53 PM
