fitting gauges
Old Dec 16, 2008 | 10:27 AM
RSTurboSI's Avatar
RSTurboSI
Default fitting gauges
ok guys i have a 3 set gauge and a pillar pod.
i know how to fit the boost,
the water temp looks easy.
now its the oil one im confused about.
it has the gauge and wirse and a install map but there is like a unit aswell. where does that go, can supply pics later
Old Dec 16, 2008 | 12:25 PM
stevenebm's Avatar
stevenebm
post whore
oil temp or pressure?if its pressure it sounds like the unit that goes in where the orignal pressure switch is.
Old Dec 16, 2008 | 12:32 PM
pani_k's Avatar
pani_k
PassionFORD Member
As above. I think you can get an adaptor which allows you to use your original pressure switch and also the sender from your gauge. If it is oil temp then just need a sump plug adaptor the same size as your sump plug with a thread tapped for the sender and that effectively becomes your new sump plug. Look at Burton Power's fitting accessories for gauges
Old Dec 16, 2008 | 02:01 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Do a search mate there has been about 3 other Threads on here recently all asking the same questions.
Old Dec 16, 2008 | 03:03 PM
RSTurboSI's Avatar
RSTurboSI
will look else where ta. and for ur info only its oil pressure..
gchristophi
Aug 31, 2015 10:36 PM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
track.focus'd
Aug 12, 2015 05:53 PM
no1trancefan
Ford Focus ST
Aug 7, 2015 09:21 PM
