Quick abs removal question & more
Hi there!
I removed abs pumps today but the brackets where pumps are attached are damn tight bolted.
Can i remove brackets without taking gearbox out of the car? Because i think the ke-jetronic side pump bracket is bolted under subframe and so i cannot take it out only loosening bolts?
What gearbox oil you recommend for S2 original gearbox with diff? How much i need oil?
And another question.. how much front shock "dustshield/bumpstop" retails in Ford?
I changed koni´s but the old dustshields are in bad condition..
Sorry my bad english..
