indicator problem
Old Nov 1, 2008 | 03:11 PM
zvhturbo29rs's Avatar
zvhturbo29rs
Default indicator problem
my escort has got a serious problem that is doing my head in. dip beam main beem and full beam are all working as they should, the indicators blow the fuses every time i go to use them, put new fuses in pop go the fuses the same thing with the hazards.any ideas??cheers
Old Nov 1, 2008 | 08:16 PM
webby80's Avatar
webby80
check the plug onto each back light mate my old s2 did the same it was them shorting out put new bulb holders in and new plugs never did it again
get on the net and look up a firm called mafco we stock their parts at work and they used to do the holders and the plugs for mk3/4 escorts in their range
Old Nov 2, 2008 | 10:16 AM
marky_g's Avatar
marky_g
Fleet Manager
sounds like you may have crossed wires
Old Nov 2, 2008 | 11:47 AM
RSmark84's Avatar
RSmark84
sounds like i might have to replace the stalk, have you ever fitted an aftermarket wheel?
sometimes if you fitt it to tight the boss eats away the stalk plastic and the metal inside it is exposed, the boss and metal stalk then blow the fuse in the box.
had this done on my XR3i, turned out i forgot to re-fit the white plastic grommet.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
