Ignition coil !!
Old 01-08-2008, 01:27 PM
S2_RST_DK
S2_RST_DK's Avatar
Default Ignition coil !!
Hi
I am having a bit of trouble understanding Haynes explanation or wiring diagram for the ignition coil setup.
I need to connect the Gotech ECU to the coil but there is no plus or minus sign on the coil, only pin no. 1 and 15.
Reading the Haynes manual is obly making me more confused. Does anyone know whats plus and minus
Henrik
Old 01-08-2008, 03:13 PM
Moonie
Moonie's Avatar
15 is ignition live (Positive (+) side of the coil) green wire on the standard loom
1 is pulsed earth from ignition ECU (Negative (-) side of the coil) black wire on the standard loom
Old 01-08-2008, 04:56 PM
S2_RST_DK
S2_RST_DK's Avatar
Excellent, why didn´t Haynes just say it like that
Thanks Moonie
Henrik
Old 01-08-2008, 07:15 PM
JesseT
JesseT's Avatar
It's the other way around.
15 - black - 12V constant when ignition is on.
1 - green - switching ground from control unit, also goes to rev counter etc...
4 - high voltage discharge.
steve.rst
15-03-2016 08:01 AM
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
07-10-2015 12:56 PM
beller
21-09-2015 04:13 AM
Quick Reply: Ignition coil !!
