Charge cooler vs Front mount intercooler
230bhp S2 in the making!!
I have a large capacity radtec front mount intercooler on my s2, there is no room at all in engine bay, im thinking about using a charge cooler as they take up a lot less space. Just after some advice on if this would be a good idea? dont know if charge coolers are any good.
Any help would be great
![Smile](https://passionford.com/forum/images/smilies/icon_smile.gif)
i had one on mine although ive recently replaced it with a GRS frontmount
i couldnt fault it to be honest but i wasnt running a lot of boost.
ive not used my car since the GRS has been on so cant really compare the two but ive noticed the water temperature is a lot higher since taking the chargecooler off.
www.ctuceilings.co.uk
Depends how you drive the car. If you drive it hard a lot or use it on track you will eventually heat up the water so it will not cool the air going through it. Intercoolers are better for high powered car.
No room in the engine bay? You do know that it goes in front of the radiator, don't you?
Dont know much about charge coolers so im new to them, any advice is greatly welcome
They will fit, you just have to move the intercooler forward. Loads of people have the fans on the rad including myself and the radiator is in the standard position.
I would not use a charge cooler as any air to liquid heat exchanger is limited in performance as once the liquid is heated past a given temperature it fails to be as effective.
Its a bit of a white lie imho that charge coolers take up less space as most solutions have a pre-rad, a pump and take which must all be located somewhere along with the associated piping
*** Sierra RS Custard ***
I use a charge cooler on my nova, enormous thing, and then the radiator for it at the other end of the car, works a treat for me, just doenst even get warm, although im currently only running about 10psi, which gives me not much more than 300bhp.
This is my one:
This is my one:
![](http://i7.photobucket.com/albums/y251/chip-3door/4m2/cooler-1.jpg)
thats mega power mate!!! impressive stuff, so would you recomnemnd c-cooler with rad in the boot etc??
Put the rad in the boot and a GRS 500 cooler at the front ![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
When i had a big front mount i mounted fans between rad & IC but with one mounted to each if you know what i mean...
lol, too big, still want my boot space, I can put the charge cooler rad in a ducted box as its only small. Ive got a radtec at the mo, is grs really a lot better?? because im mounting the intercool forward i think im going to have to remove the bonnet release so bonnet pins will have to be used :-(
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=170219741089
wow seems like a lot of complicated problems for no gain to me, so far we have been discussing boot mounted tanks, boot mounted radiators and other bits ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
bit drastic imho
simply fix the problem, other people can run 250 to 300 hp without resulting to this kind of action why can you not ?
my front mount intercooler touches my radiator and both performs really really well
bit drastic imho
vdun01
Ford Fiesta
05-10-2017 08:14 AM
