FUEL PUMP BRACKET
Old Nov 2, 2004 | 05:24 PM
townie9371's Avatar
townie9371
Default FUEL PUMP BRACKET
RESTORING UNDERNEATH OF MY S2 RST AT THE MOMENT.AND I CANT GET THE FUEL BRACKET(S) OFF TO PAINT UP.
BOTH THE BOLTS SPIN WHILE TRYING TO REMOVE THE PLATE BRACKET CLOSEST TO CAR.
ALSO WITH THE OTHER BRACKET WHILE TURNING THE 3 BOLTS I HAVE BROKE THE RUBBER TUBES NR THE ACTUAL PUMP.
HOW DO I GET BOLTS OFF?AND WHAT PARTS DO I NEED TO ORDER FROM FORD TO GET THIS JOB DONE.
ANY HELP MOST WELCOME
Old Nov 2, 2004 | 05:37 PM
sounds like you will have to cut them off like i had to,one of the bolts goes up into the boot floor which is stuck down and looks like a washer,the big bracket you can buy from fords with the new mount rubbers in it already the other 2 parts of the bracket i powder coated as they were alright,the 3 little rubbers are still avaliable to,and so are the bolts which go to the body,they list a couple of lenghts but i just ordered the lot,all the other nuts,bolts i got in stainless,hope this helps,sorry no part numbers i cant find the receipt.
Old Nov 2, 2004 | 05:55 PM
townie9371's Avatar
townie9371
THANKS FOR ADVICE TWINS.
HOW DO I ACTUALY CUT THE BOLTS SEEMS THERE IS VERY LITTLE ROOM BETWEEN THE BRACKET AND FLOOR OF CAR.
ALL BRACKETS ARE SOUND BUT NEED TAKING OFF TO RUST PROOF AND PAINT
ALSO DO I HAVE TO TAKE THE ACTUAL PUMP OFF WHEN REMOVING BRACKETS.
Old Nov 2, 2004 | 06:23 PM
BODGE's Avatar
BODGE
you need to cut both bolts i think i slid the hacksaw blade in the top of the rubber mount then cut both off the boot one then will be fecked a you need a new one from ford and it will need painting the other one any bolt long enough with two nuts is ok
the new boot bit can be seen top left of bolts in pic, get a new pump mount plate at ford when you there, think it was 25 notes
mark
Old Nov 2, 2004 | 06:26 PM
BODGE's Avatar
BODGE
also when its off the small rubber mounts in side that hold the pump WILL snap when you try undoing them the are cheap new tho
mark
Old Nov 2, 2004 | 06:40 PM
townie9371's Avatar
townie9371
cheers bodge.thanks for help.
i will keep pump mount plate,rust will wire brush off then i can rust proof it.
can rubber bits i saw off be bought without pump mount plate bracket
Old Nov 4, 2004 | 02:26 PM
adamS2RST's Avatar
adamS2RST
Got exact same prob at the mo...pain in the arse trying to get at the fookers to cut
Old Nov 6, 2004 | 04:58 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
plate is 35,,rubber mount bolts 5 each,cradle+clamp+bolts total cost of pump bracket with all fittings 120,,,4sure,,im working on a none rot ali billet bling item at the mo,,gonna be bout 170 to buy,,,only making a limited no,,,totally blingingdales,,anyone interested?
BILLET ALUMINIUM!!!!!!!! ONE OFFS!!!!!!
Old Nov 6, 2004 | 05:13 PM
townie9371's Avatar
townie9371
JOB DONE PLATE £31.25,BOLT THAT GOES TO BOOT £9,INSULATORS X3 £14.50,OTHER BOLT BOUT £1.50(PRICES INC VAT).CLEANED OTHER 2 BRACKETS UP DIPPED PAINTED AND REUSED.
Old Nov 6, 2004 | 05:30 PM
adamS2RST's Avatar
adamS2RST
Why not just get one of these stainless jobbies which also look for 55 sheets?
https://secure.encryptedspace.com/au...t_detail&p=162
Old Nov 7, 2004 | 10:57 AM
akito-man's Avatar
akito-man
ive been asking for moths bout a bracket,,now this,,,, fooks sake
Old Nov 7, 2004 | 11:00 AM
adamS2RST's Avatar
adamS2RST
I asked just the other day, got this link sent to me straight away.... I have emailed the company, they seem very helpful and all you need are the original 3 rubber flexi mounts or something, when I actually get my old bracket off I will be ordering one
Old Nov 7, 2004 | 01:56 PM
townie9371's Avatar
townie9371
looked at the link.seems that it doesnt come with the mounting plate that actualy bolts to the bottom of car,this is wot rots the most.
Old Nov 7, 2004 | 08:55 PM
akito-man's Avatar
akito-man
juss ordered the flexi rubber bolts 5a each ,,mr henrys gaff.
Old Nov 7, 2004 | 09:02 PM
akito-man's Avatar
akito-man
ive been asking for months about a bracket,,now this,,,, fooks sake
i want one of those ,,,,,
my billet makers been telt,,,like,,,,still gonna make some ,,engraved rs billet carriers though.
Old Nov 7, 2004 | 09:50 PM
adamS2RST's Avatar
adamS2RST
plus you can still get this from frauds
Old Nov 10, 2004 | 06:52 AM
adamS2RST's Avatar
adamS2RST
Still trying to remove my original one I had the idea of cutting one of the bolt heads off and trying to knock it through....hmmm maybe not!
How can I get in there to get at the font bolt that sits up in between where the rear wishbones join! can't get fook all on it! The back one shouldn't be a prob as that whole bit in the boot has to come out....
Any idea's?
Old Nov 10, 2004 | 08:11 AM
Any idea's?
it was a case of cutting it for me as it was spinning
Old Nov 10, 2004 | 08:20 AM
adamS2RST's Avatar
adamS2RST
Hi mate, yea, but it is a right pain in the aRSe to get at, what did you use to cut it?
Old Nov 10, 2004 | 04:16 PM
townie9371's Avatar
townie9371
i got hold of bolt with mole grips and wriggled it making the hole its in bigger,if you do this for a while the bolt just pulls out.when you put in new bolt all you need is a washer.
worked for me
Old Nov 14, 2004 | 04:02 PM
adamS2RST's Avatar
adamS2RST
No way was that happening! Anyway, got medievil on ot's ass and went to work with the bolt croppers Let's just say the cradle looks like a mangled mess, but hey it is off, which is what i wanted Now gunna order the bling effort and get the other bits I need, sorted.
Old Nov 15, 2004 | 08:07 PM
akito-man's Avatar
akito-man
rubber studs from henry,,,15notes,for three,,no washers or nylocks included either
Old Nov 15, 2004 | 08:55 PM
adamS2RST's Avatar
adamS2RST
Yup, got all my bits sorted..... i think
Old Nov 20, 2004 | 12:52 PM
akito-man's Avatar
akito-man
was it juss the flexi studs of ford needed then????
Old Nov 20, 2004 | 01:16 PM
adamS2RST's Avatar
adamS2RST
Well, what I needed (or "think" i needed so bought anyway )
1 x mount as bodge has pictured at the top
1 x bootwell plug again as pictured by bodge
3 x the rubber moun things, as you say dont come with the nuts it seems...
3 x nuts, assume these are for the rubber mounts, not sure yet
That's all i needed as I have the other mounts from AS which look cool, I will take a pic when it is all assembled again
Old Nov 20, 2004 | 06:41 PM
BODGE's Avatar
BODGE
the nuts you need can be go for halfords they do an asortment (spelling) of nuts in a box and the small ones are what you need, the rest come in handy aswell
make sure do dont just tighten the nut up as i think the rubber will twist and snap, you need a spanner each side to tighten against each other, you will see what i mean when you come to do it
mark
Old Nov 20, 2004 | 11:06 PM
adamS2RST's Avatar
adamS2RST
Cheers for the tips Mark.
JK12
33
Apr 26, 2021 12:09 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
15
Oct 7, 2015 03:43 PM
