Can i run a Stage 3 Hybrid like this? >>>
Old 02-11-2004, 12:44 PM
Gr8Ride
Gr8Ride's Avatar
Default Can i run a Stage 3 Hybrid like this? >>>
Well after 3 weeks of first time RS ownership my turbo has blew up
Got the chance of a cheap Stage 3 so just wondering how it would run: basically my car is pretty much standard apart from 1.8 Zetec bottom end, full Scorpion, Dumpvalve, K&N and as far as i know it hasnt been chipped.
Just worried about the lag? Thanks, Joe
Old 02-11-2004, 06:28 PM
BODGE
BODGE's Avatar
it will be fine
mark
Old 02-11-2004, 06:43 PM
ballin
ballin's Avatar
stg3 is pretty laggy so im told, how that would work with a 1.8 zetec bottom end i dont know.
Old 02-11-2004, 10:20 PM
Gr8Ride
Gr8Ride's Avatar
Yeah thats what im worried about, as am i right in saying that the highest boost i can run is 10psi without it being chipped?
Old 03-11-2004, 05:43 AM
james_birch
james_birch's Avatar
u would be right about the boost!...stage 3 aint to much laggy'er! just keep the revs up!
Old 03-11-2004, 04:23 PM
ballin
ballin's Avatar
yeah around 10psi std.
i suppose james is right about the lag if you keep the revs up, but that aint always possible!
depends really on your future plans, and the price of the stg3!
Old 03-11-2004, 06:56 PM
bud-weis
Football Cwazy
bud-weis's Avatar
if your new to rs ownership then i would suggest you have the blown turbo looked at.
an expert company will be able to tell you what caused the failure. if it's just wear and tear then fine, but if it's something else then you'll need to get that fixed first otherwise your new turbo will go the same way
Old 03-11-2004, 09:41 PM
Gr8Ride
Gr8Ride's Avatar
Yea i know what possibly caused it, a dodgy oil return pipe. But that is all being sorted when it goes to the garage, im just really wondering what its going to be like to drive with this Turbo on compared to the standard turbo before? an in is it going to be going to be horribly undriveable or really slow between gearchanges?
I dont dont really have anything amazing planned for the future just having it chipped. Thanks, Joe
Old 04-11-2004, 12:03 AM
bud-weis
Football Cwazy
bud-weis's Avatar
i don't think it will be that much different to your old one to be honest. you may find spool up is just slightly slower but if your running standard-ish boost
there won't be much difference. you will be better off when you come to chip it though cos the tuning bug is very contageous and no doubt you'll be planning this and that when you get power hungry. at least you'll have one of the main ingredients to run big power ready and waiting. all you'll need is a larger intercooler and you should see about 175bhp or so at about 15 psi with the chip, maybe even more
with the dodgy oil return, definitely do an oil change and probably a good flush out wouldn't hurt. i would possibly have your oil pressure checked as well, might be a dodgy oil pump causing starvation. never really heard of a return causing failure but hey , they are built by ford
anyway good luck with the turbs
Old 04-11-2004, 01:49 PM
mattbibs
mattbibs's Avatar
the answer is to get it chipped!
Old 04-11-2004, 10:41 PM
escort1989uk
escort1989uk's Avatar
i fthe turbo is cheap enough buy it if you don't like it take it to a turbo repair place and trade the stage3 and your knackered turbo in for a stg2 or one they might surrgest if not go get the chip evo are having a xmas sale look under traders
JK12
33
26-04-2021 12:09 PM
wheelwizardrefurbs
24-09-2015 08:35 PM
dombanks
21-09-2015 08:38 PM
3doorcozmess
15-09-2015 06:06 PM
Eigdoog
13-09-2015 05:46 AM
Quick Reply: Can i run a Stage 3 Hybrid like this? >>>
