wheel rubbing
wheel rubbing
my mate has got a s1 turbo and has got a set of 8x17 compomotives on it with 215/40 toyo tyres
has anyone else got the same setup or a similar setup did you have any problems with rubbing? if so how did you cure it
cheers billy
cheers billy
im running that setup on my mk3 se cab.Mine are th2's. I had to trim the rear arches back as much as poss,and trim the fronts down a tad. Ive got no rubbing whatsoever and is quite low too.It all depends on what the offset is of the wheels on his car? mine is et38 which is spot on!!
Adam Graham
06-09-2015 06:04 AM
