Indicators, dipped and full beam not working
Old 06-07-2008 | 01:43 PM
muz's Avatar
muz
Wye Valley Hardcore
Default Indicators, dipped and full beam not working
Having trouble with the indicators etc on my S2. I've changed the indicator stalk, relays all seam to be working but this is happening;
* No indicators, either side, but hazards work.
* Sidelights work and full beam comes on if you pull on the stalk. Dash illumination works.
*dipped beam doesnt work, niether does full beam.
Any suggestions?
Old 06-07-2008 | 07:30 PM
ROB7656's Avatar
ROB7656
try another stalk mate.
Old 06-07-2008 | 10:01 PM
muz's Avatar
muz
Wye Valley Hardcore
Just wondering if changing the stalk again would work, as the problems are identical whatever stalk I use.
Old 06-07-2008 | 11:54 PM
johnnysash's Avatar
johnnysash
get the haynes manual out and start looking at them diagrams. Sounds like a broken wire for an ignition 2 12volt supply to the switch. check the condtion of the wires carefully from the switch back to the fuse board
Old 07-07-2008 | 06:17 PM
bad boy rs's Avatar
bad boy rs
Get a decent un cut loom mate, ive been having the same problem with mine for ages and it looks like the best option is to change the loom for one that i know works, a pain in the arse i know but worth the hassle
Old 07-07-2008 | 09:50 PM
muz's Avatar
muz
Wye Valley Hardcore
Lol after building and then breaking the fiesta I've had enough of playing with looms It's off to the garage Wednesday to see if they can sort it.
jessie_rs
11
03-06-2019 05:57 PM
Jack and the Beanstalk
15-08-2015 05:27 PM
RIB1122
12-08-2015 09:51 PM
col93saphcos
07-08-2015 04:21 PM
