starting problem
Old May 28, 2008 | 07:44 PM
juffer's Avatar
juffer
Default starting problem
im having problems with my car not starting unless i use easy start. once its started using easy start it will run and drive fine till i come to a junction and it will stall and will not start unless i use easy start again!
any ideas?
juffer
Old May 29, 2008 | 01:40 PM
mentalasanything's Avatar
mentalasanything
any ideas?
juffer
Sounds like dodgy wiring to the easy start. almost as if it has a broken connection between the barrel and the easy start unit, but the connections after the unit are fine.
Lee
Old May 29, 2008 | 02:05 PM
T28 RST's Avatar
T28 RST
Ok then
Wats easy start ??
Old May 29, 2008 | 02:11 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
i thort easy start was a spray that u spray in to the intake to get an engine running!"!! maybe im wrong
Old May 29, 2008 | 02:21 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Lee
I'm sure he means this....
Old May 29, 2008 | 02:33 PM
rickbartlett
G911 TTA
yeah thats wot i fort
Old May 29, 2008 | 04:33 PM
orionmojo's Avatar
orionmojo
split air pipe or leaky gasket on the inlet maybe?
certanly on carb'd engines this would be my first check.
Old May 29, 2008 | 06:04 PM
juffer's Avatar
juffer
you got it , its the famous spray can,
Old May 29, 2008 | 07:48 PM
rickbartlett
G911 TTA
engines become addicted to that stuf
Old May 29, 2008 | 08:34 PM
Moonie's Avatar
Moonie
As above i would be checking for air leaks first
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
