s1 & s2 master cylinders
21-05-2008, 10:25 AM
are they the same?
22-05-2008, 02:01 PM
no pal s2 is much much bigger
tim
22-05-2008, 08:00 PM
s1 23mm i believe, s2 are 25mm and only have two exits for brake pipes as it has abs
22-05-2008, 08:26 PM
i use a s2 item with t peices much better pedal
25-05-2008, 10:09 AM
so gaz do u use the series2 set up with out the abs as i have a series 1 and the brakes are shit
25-05-2008, 08:23 PM
my s2 with t pieces
25-05-2008, 10:03 PM
Quote:
Originally Posted by
moesin2005
yes just use the s2 master cylinder with the 2 outlets and run the two pipes to the t peices which then run to your four pipes hope this makes sense ive been on the pop
, will post some pics up tommorow
26-05-2008, 08:03 AM
are they piped in on the diagnal say one outlet to the front right and rear left and the other to the front left and rear right cheeRS
26-05-2008, 07:28 PM
moesin2005
yes mate thats how i did mine
01-11-2015 06:53 PM
muzzman1
30-09-2015 08:59 PM
