S1 passenger wing washer bottle
Hey guys are these still available to buy from a ford dealer, or am i goin to have to search for a secondhand one, as mine has gota split in the side, Chris
Yeah fella, il get you a pic up. I assume you are talking about the one that fits up under the passenger wheel arch? I beleive this is the standard bottle for the S1. The bottle should have two brackets moulded into it. Mine is bolted to the inner wing, next to the pass wheel using two bolts. You have to feed the neck of the bottle through the large hole on the inner wing (looking from the engine bay). A rubber grommet is then fitted into the large hole in the wing around the bottle neck. Im not sure where the tubing for the washer goes as iv not got that far!. I will send you some pics tommorow evening, as its too dark now. PM me ure email addy, Chris
S1 Database Editor
rallyst: 2nd hand items are the best option. not sure if you can still get one from for,d but plenty of 2nd hand ones around. Or plastic weld your item up.
Nick: replied on your other topic.
DavidK
27-09-2015 02:55 PM
