Screen Washer Bottle
Old 25-04-2008 | 03:57 PM
NicktRST's Avatar
NicktRST
Default Screen Washer Bottle
Does anyone know where this fits into my bay, it looks like it doesnt go under the arch?????
Old 25-04-2008 | 05:29 PM
antony215's Avatar
antony215
Escort Rs Turbo
It should fit under the arch/inside of the passenger inner wing and the neck of it pokes through into the engine bay
Old 25-04-2008 | 05:30 PM
NicktRST's Avatar
NicktRST
thats what i thought, but its a square bottle and i have no hole in the arch!!!
Old 25-04-2008 | 05:35 PM
gus's Avatar
gus
i think some of the early cars had it sat just off the n/s wing
could be wrong thou, any pics? might help
Old 25-04-2008 | 05:37 PM
NicktRST's Avatar
NicktRST
thats what i thought like the rs 1600,its doing my head in. I cant see how it fits on
Old 25-04-2008 | 05:52 PM
antony215's Avatar
antony215
Escort Rs Turbo
What reg is the car??
Old 25-04-2008 | 05:53 PM
NicktRST's Avatar
NicktRST
its a 1985 b plate mate
Old 25-04-2008 | 06:00 PM
antony215's Avatar
antony215
Escort Rs Turbo
Im sure it should bolt in the way i said (even the manual shows it there) as i thought it was only the cab's,xr3's and rs1600's that had the bottle in the bay. I thought they moved the bottle in the S1 due to the air box being there
Old 25-04-2008 | 06:04 PM
NicktRST's Avatar
NicktRST
the manual says it might be this bottle. im looks like it goes in the bay just by the shape of it. but i cant remember how it fits in. some pics would be good if anyone has this
Old 25-04-2008 | 06:05 PM
gus's Avatar
gus
has it got a neck on it? strange that you have no hole in the wing
guess it must go inside the bay
Old 25-04-2008 | 06:07 PM
antony215's Avatar
antony215
Escort Rs Turbo
What manual are you reading from the haynes?? The S1 workshop manual shows this
Old 25-04-2008 | 06:09 PM
NicktRST's Avatar
NicktRST
its just a square bottle with no nuck, then coming off it you have water pipe which goes to a small red motor. coming out of the motor is your feed to the jets, i also have two green cables going into my passanger wheel arch through a grommet which have been cut????
NicktRST's Avatar
NicktRST
the haynes
Old 25-04-2008 | 09:54 PM
OLDSKOOLRYAN's Avatar
OLDSKOOLRYAN
had a similar problem, tried to fit a bottle off h reg s2 on my f plate s2 and it wouldnt fit.
there must be different bottle shapes
Old 25-04-2008 | 09:55 PM
NicktRST's Avatar
NicktRST
Its Square And I Know It Came Off The Car, Just Trying To Figure Out How It Goes Back On.
Old 26-04-2008 | 12:59 PM
NicktRST's Avatar
NicktRST
Anybody Shed Some Light On This????????
Old 27-04-2008 | 12:26 PM
boothy's Avatar
boothy
i converted my 3i to turbo running gear,they sit on the wheel arch,but if u want you just have to drill a hole and change the bottle,,hope this helpes ,,im doin mine when i get the chance
Old 27-04-2008 | 02:13 PM
iansoutham's Avatar
iansoutham
OCD Victim
Okay, enough of the guessing.
Pre 1987, Escort MK3 and MK4 cars have the washer bottle on the nearside wing. It is a squarish bottle with an outlet for the pump near the front of the car. It is held on with 2 Phillips screws to the inner wing.
On later (post 1987) cars, the bottle fits inside the inner wing and the neck extends through a pre-made hole into the engine compartment. This co-incides with the time that Ford decided to fit front arch-liners to their Escort models.
The bottle was also changed in 1989 (90-spec motors) to allow for the EFi models to have their coolant expansion bottles on the same side. Using the 1987-1989 bottle, this would prevent the 2 items locating securely, so the neck and fitting holes were altered slightly.
Pre 1987 (MK3 and MK4 locate the same)
Post 1987 (model shown here is a 1991 model)
Hope this helps....
Old 28-04-2008 | 11:30 AM
NicktRST's Avatar
NicktRST
The squisher bottle which came off is square, without a slopped bottom which runs on the inner wing. How does the bottle attach on???? if i cant get it to fit ill get my mate to make a new bottle. he is a fabricator. Cheers for the photo.
Old 28-04-2008 | 12:23 PM
iansoutham's Avatar
iansoutham
OCD Victim
Sounds like you have a pre 1983 model washer bottle. These bolted to the inner wing down by the chassis leg using a bracket that bolted to the wing first, then the bottle slid into the aforementioned bracket. They were only fitted to the models with 2 bolts on the front suspension top mounts. A B-reg should have single-bolt front suspension and the bottle as fitted to the Blue car.
Old 28-04-2008 | 03:28 PM
NicktRST's Avatar
NicktRST
Cheers mate ill have a look.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
155lee
24-10-2015 11:11 AM
DavidK
27-09-2015 02:55 PM
Quick Reply: Screen Washer Bottle
