boost gauge in mk4 s2 escort RS turbo - problem
hi,
can some one help me out, i fitted a boost gauge to my rs turbo but when i put the gauge on, the needle drops to -20/-25 and when i rev the car, the needle goes back to 0
i have took a feed from my dub vale, is this right??
ta
ta
thats right
boost guage will only show boost pressure when there is load on the engine, ie driving and will show negative vacum on idle..
well thats right i hope....
i thought that the needle should sit at 0 and go up the clock when i rev the car?
atm the needle drop to -20/-25 psi (bottom of the clock) and when i rev the car, it goes back to 0 psi
when i had a 2L turbo tomcat, the needle sat at 0 when it was not being rev and went up the clock when you rev or drove the car,
is this not the same on the escort?
my one will not go into +psi tho
i will try and take a few pic's it may help
i have took a fed from my dub vale, is that right or is there other way i can fit it?????
well i rev the car and went from -psi to 0psi, rev it up to about 6,500rpm
i have not tryed driving it with it on, i got a little "pee'ed" off and took it off again.lol
looks like it's quite normal, i thought you should get a little boost when you rev is that high, but just go out on the road.
The negative on idle is normal you're car should go on the streets in till 0,5 bar boost +, whenn it's standart
it wont go up untill you drive it mate,mies sits at -25 then 0 on revving then goes into + when hitting boost,
take it off the top of the inlet tho mate,less hose= less pipe to vaccum
You took the feed from the dump valve? So you will only see pressure when the dump valve vents?
As above, take the feed from the plenum. (T into one of the little thin pipes that comes off the top of the plenum)
IIRC mine is T'd into the boost pipe that goes to the ECU, behind the heater box so you cant see it...
Been like that for over 10 years, never had a problem
Versus_Creations
24
05-08-2015 09:32 PM
