poly bush
Great Company, one of mine on end of arb got a little chewed up (entirely
my fault/using my favourite tools ie hammer+screwdriver) during reassembly.
I'd used them for 2 years, had them on and off many times and when I phoned to buy another Neil said 'email me your details and I'll bung one
in the post without charge'.
So,- Cracking products, service and much cheaper than the 'others', whats
not to like?
not to like?
The bushes are very soft, softer than OE bushes in some cases, but they fit well. I've been reasonably happy with them, keeping in mind that rubber bushes are harder to find and they are more expensive.
on my s1 the rear the wishbone bush is bigger than the hole it has to go into
has the outer metal sleeve got to be pushed out or something (talking about the rear main bush that bolts to the body)
Im tempted to buy a full set for my mk2 orion if there any good? Ill just order a full set for a s2, should be all the same. . . Deflex are still advertised/ trading under deflex in fastford every month. . .
Im tempted to give them a go. . . Im sure if i ring them they should be able to sort me something out. I have got a s2 front anti rollbar to fit anyway. So would just be the rear that may be a problem. . . Anyone else used deflex and happy with them?
Originally Posted by Mixja
used em on loads of my turbos, never had any probs...
polyurethane is polyurathane, dont think any of them are any better or worse than each other...
Thats good to hear... money saved then can be spent elsewhere...
DavidK
27-09-2015 02:55 PM
