oil light flashing
oil light flashing
on xmas eve my bottom end went, so im in the process of fixing that what i wanna know is why was the oil light flashing comeing on and off???
was it because of the oil pump?
cheeRS
cheeRS
same thing happened to me, was flashing when warm mostly, then when goin down the motorway, knock knock who's there two shells fooked on the con rods and one well bugered crank, this was on my plans on the to do list then it was too late
mines nealry back on the road now, just need to sort the brakes, and a set up, got a nice new engine built using what i wanted from my engine which was the block lol, its soo close its annoying its just finding the time to sort the last little bits, and getting it trailored to be set up
orion=mini saff
normally the oil light flickers on idle and goes out when out rev it normally means you losing pressure,either thru the shells or a weak oil pump,or a blocked strainer
what a blocked strainer oil pick up pipe?
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
