ULTIMATE CVH HEAD
Passionate about fords
ULTIMATE CVH HEAD
hey everyone,
this may start a bit of debate but ive always wondered who makes the ultimate cvh head ????.
alot of people on here have, over time, used various companies for there heads from jamsport to nms, one mans stage isnt anothers as there isnt strictly a standard for different stages when it comes to heads if im right but with the amount of modded cvh`s on this site, input from as many people as possible may just point me in the right direction, if and when, i want a new head.
thanks in advance
dave.
thanks in advance
dave.
Originally Posted by crazycage
jamsport heads are really good
Originally Posted by G2RSR
A NMS head they have the fastest RS Turbos around proven
Always assuming you can get the elusive so+so to make you one.
no one has ever had all the tuners best flowing cvh heads and tried them on the same car on the same day to see which one produced the most power so this would be a question that no one would know the answer to.
going from a standard mfi head to a ported head you would see a huge improvement and then that head would be recommended to all, and because a car does the numbers does'nt mean the cylinder head the best there are so many other factors to take into account. But you wont go wrong acquiring a head from nms,area six,pumaracing,cnc heads,jamsport and a few others i have'nt mentioned they all achieve vast improvements over standard...
sean
sean
turboboss
sean have you sorted your engine yet as i heard you bent your inlet valves how did that happen ?
sean
i agree a mag test would be great for all us customers but i doubt it would happen as if one came out clearly on top then the others may loose business coz of it so for that reason even if a mag wanted to do a test tuners, that would be willing to put one of there heads forward for testing, would be thin on the ground..........would certainly be an interesting feature though if it did go ahead.
regards
dave.
regards
dave.
Jamsport ran a back to back test in performance ford in july 2006.Standard head with a standard cam, then a ported head with standard cam then ported head with a piper cam. Total improvement with piper cam and ported head was 48BHP. I belive Nick from the mag still has it on his car.
yeah good results but still doesnt clear up who makes the better head out of all the tuners. originally got a quote for a full head from jamie but just wanted more feedback on other tuners i havent used.
cheers
dave.
cheers
dave.
sean
hiya sean, are you still running a dave baker UBV cvh head ?????. how did you find the head ?????. did you take any pics of it before you built your engine, if so would you mind sending them in a pm so i can have a look ????.
thanks mate
dave.
thanks mate
dave.
thanks mate
dave.
thanks mate
dave.
sean
sean
thanks mate
dave.
thanks mate
dave.
sean
sean
Bodybuilding
Location: Cannot be identified by the information given.
hi m8 sorry i've been off line for a while yes i am still running a dave baker 45mm valve head i'll pm you some pictures. the head excellent flows a serious amount of air, just a few things which held the power back on my last engine.. all sorted now just waiting for my live mapping session.
sean
hi sean can you pm me some pics also as im thinking of getting me one of them 45mm valve puma racing heads
To be fair,
- The std head needed to be cleaned, checked and rebuilt before test,
- A new std cam,followers, valve springs needed to be fitted,
- both cams needed the lobes checking for lift before and after the tests,
- both cam's needed to be timed correctly with a vernier,
- C/r's needs to be measured and adjusted till both the same.
- The same boost, AFR, and ACT needed to be log and seen
- the only things that should be changed, ign timin needs setting, and fueling needs to be set to the same AFR.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
