Advice on EFI Conversion
Old Dec 23, 2007 | 02:08 PM
slimrs2k's Avatar
slimrs2k
Default Advice on EFI Conversion
Can anyone give me some pointers on an EFI conversion for my D reg series two.
I'm gonna get the engine rebuilt over the next couple of months but was wondering if its worth swapping to efi management while i'm on.
What bits do i need, to do the conversion properly and if any one has any opinions on how to do it the they would be much appricieated as well.
An if anyone has done it whats it like to drive.
cheer folks and merry christmas
Old Dec 23, 2007 | 02:13 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
I'm putting weber L8 on mine over the next few months, have a look on here: http://oddkiddcreations.co.uk/forum/index.php
Everyone seems to rave on about it, more people can map weber than most other systems too and sensors and most bits are really easy to get hold of
Old Dec 23, 2007 | 03:37 PM
Billy_RS's Avatar
Billy_RS
www.rsbible.co.uk
Old Dec 23, 2007 | 04:59 PM
Daveysaff's Avatar
Daveysaff
Billy_RST
I've been searching for that!! Nice one
Old Dec 23, 2007 | 05:38 PM
DazC's Avatar
DazC
That is wrong you know. Not that many can map Webber Marrelli. Aftermarket systems can be mapped by anyone at all.
More people can map Marrelli than EEC OFAB/C if that is what you mean.
Old Dec 23, 2007 | 05:41 PM
Daveysaff's Avatar
Daveysaff
Yeah thats what I was getting at
Old Dec 23, 2007 | 07:14 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Although many after market systems can be mapped by anyone trying to find professionals willing to do this with some 'after market systems' can be difficult, no matter what end of the country I am in I can find someone willing to map, support and work on Webber management... Wiltshire, Blackpool, Essex and Middlesex to name but a few area's... This is without mentioning the vast amount of experience people have with this management.
When I was researching management, popular after market choices often recommended on this forum have limited numbers of professionals willing to map them by comparison
Old Dec 24, 2007 | 05:53 PM
slimrs2k's Avatar
slimrs2k
cheers folks
Old Dec 24, 2007 | 08:53 PM
mitchrst's Avatar
mitchrst
1981
jamsport diy go-tech efi with all labeled loom £300 uses most of the mfi sensors
including the rs turbo distributor no crank sensor to worry about
made 265 with performance fords rs turbo 18 psi
Old Dec 25, 2007 | 04:54 PM
Barry R's Avatar
Barry R
has any 1 got a link for jamsports diy go tech?
Old Dec 25, 2007 | 08:43 PM
LEE-RS's Avatar
LEE-RS
Custom
from there website
http://www.jam-sport.co.uk/gotech.asp
Old Dec 25, 2007 | 09:01 PM
Barry R's Avatar
Barry R
is this go-tech stuff any good?
is it any better than running ofab?
Old Dec 26, 2007 | 04:06 PM
sas's Avatar
sas
should be good!
The Gotech ECU is a stand alone ECU, which allows you to MAP the car for any configuration of parts, and if you change any componant you just tweek the map, not have to buy a new chip.
You also get a new engine loom so you dont have to use a 13+ year old loom.
But its not Ford!
Old Dec 26, 2007 | 04:08 PM
Barry R's Avatar
Barry R
so which would be best for power and reliability
i will be using a 1900 tall block cvh with it
Old Dec 26, 2007 | 04:12 PM
sas's Avatar
sas
should be good!
They both will make the same power (down to the tuner)
Jamsport has fitted over 150 Gotech ECUs over the last 6 years and I cant think of any reliability issues.
Old Dec 26, 2007 | 04:22 PM
Barry R's Avatar
Barry R
im not sure which 1 to go for now
i suppose it will have to come down to cost or reccomendations
Old Dec 26, 2007 | 04:36 PM
LEE-RS's Avatar
LEE-RS
Custom
i would go for gotech myself alot more features than ofab like closed loop lambda sensor etc and ofab drinks fuel when mapped for high power
plus that what simon (SaS) was using when he did 166 mph in his zvh
Old Dec 27, 2007 | 11:11 AM
Turbocabbie
Top Cab !!
You can run closed loop, dizzyless, etc with cossie management which can be mapped by more experienced people at vastly more locations across the UK
Although Simon used Gotech when he did 166mph its not what he is using now with his new engine although I do not know the reason for this, I expect there is one.
I believe that Oli was also not using Gotech when he did 173.5mph with his CVH
The best advise you can give anyone who is looking for management is to find who you want to map your car and take their advise regarding what they are most experienced with, every management system has good and bad points
Old Dec 30, 2007 | 05:51 PM
slimrs2k's Avatar
slimrs2k
If i go down this route do i need all the FRST bits then or is it just a straight swop?
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
