XR3i conversion to RST??
Old 25-11-2007 | 02:45 PM
baz's Avatar
baz
Default XR3i conversion to RST??
Hi,
has anyone on here converted a XR3i (Efi model) into a RS turbo.
If so what do you need, I know you need an RS Turbo engine, Turbo, Intercooler etc, But what about wiring?? I have the ECU already.
Thanks
Baz
Old 25-11-2007 | 04:00 PM
Billy_RS's Avatar
Billy_RS
www.rsbible.co.uk
Old 25-11-2007 | 04:35 PM
anodised's Avatar
anodised
i would do a mix of fiesta turbo bits and escort
engine loom inlet and ecu(ofac) from the fiesta
gearbox turbo from the escort
that would be easier cause you already got the efi loom
Old 25-11-2007 | 07:04 PM
baz's Avatar
baz
Thanks for your help, I was wondering if a RS turbo ECU would just plug straight into the XR3i loom without any mods??
I am thinking of buying a Mint XR3i I have seen and converting it to a RST thats all.
Old 25-11-2007 | 07:49 PM
anodised's Avatar
anodised
no it wont work cause the erst is mfi
frst is efi
Old 26-11-2007 | 04:05 PM
RSmark84's Avatar
RSmark84
you can EFi an ERST, but it costs alot.
best of buying a proper escort rs turbo instead.
Old 26-11-2007 | 05:29 PM
sm's Avatar
sm
as above try and buy a rs turbo as the cost of converting the car to turbo plus the fact that the ins will be the same as a rs turbo and it will be worth less than a rs turbo when u come to sell it on makes it not a very worthwhile conversion
Old 26-11-2007 | 07:34 PM
rst in breaking's Avatar
rst in breaking
wont cost much at all to do as i done it to mine, exhaust sytem Ł80 (i have one for sale) use ofab ecu from fiesta as it is better) 2.5 bar map sensor, need to change i think 2 pins in wiring for it to control boost, change rad and fan(i have too) then you'll need boost pipes etc, i converted my 1.1 to run fiesta turbo for around Ł400, but would def go forward using efi instead of mfi, more options available
Old 26-11-2007 | 09:51 PM
©hatter Box's Avatar
©hatter Box
if your cab is efi now. all you need is ofab ecu ofab map sensor a few pin changes and make sure you get an fista turbo lump pice of cake done it lotss of times
mk3ste
17-10-2021 11:09 AM
A.t.p
23-10-2015 08:54 PM
07-10-2015 01:56 PM
stephenb4506
33
02-10-2015 07:25 PM
SMILER258
28-09-2015 10:04 AM
Quick Reply: XR3i conversion to RST??
