No boost!!!
Old Jan 23, 2004 | 03:53 PM
Default No boost!!!
posting this for a mate as hes still in the stoneage
his RS recently just stopped boosting cant heere the turbo spooling up at all the boost gauge just reads vaccum then 0
he recently fitted a new -31 actuator set at 5psi if it helps
Old Jan 23, 2004 | 03:58 PM
JesseT's Avatar
JesseT
Probably the actuator rod has become detached from the wastegate.
Old Jan 23, 2004 | 04:21 PM
thats what i thought but the exhaust was too bloody hot to look
anything else...
Old Jan 23, 2004 | 04:38 PM
def ur actuator and runing 5psi
Old Jan 23, 2004 | 05:07 PM
flashpoint's Avatar
flashpoint
Have had this happen to me some time ago, one mint running 16 psi the next no boost!!! The actuator rod had gone limp, after a lot of messing about, removed the turbo,removed the elbow and the pipit valve was no longer on the end of the arm!!!
It must have gone down and out of the exhaust
Hope the is not you problem
Steve
Old Jan 23, 2004 | 05:11 PM
WutangRS's Avatar
WutangRS
i put a reply up about something similiar for someone.
ive seen the wasthgate plate thats inside the turbo crack so it leaks. ive also seen them where they have shatted completey and like flashpoint said disappeared down the zorst
Old Jan 23, 2004 | 06:08 PM
will check the rod asap
the reason it was running 5psi was cause we couldnt pull the arm out any further it really needs a setup anyhow
Old Jan 23, 2004 | 06:15 PM
come to think of it is it the longer the arm more boost or shorter
Old Jan 23, 2004 | 07:12 PM
flashpoint's Avatar
flashpoint
The shorter the arm the more boost you will get
Steve
Old Jan 24, 2004 | 12:51 AM
Oh come on geeza!!!!!! Shorten the damn thing! I aint surprised that you aint getting any boost with the rod being as long as your arm!
Old Jan 24, 2004 | 05:00 PM
its a saftey thing mate his car runs like a bag of spanners
my cars not on the road yet
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
