dumpvalves who uses then ??
#41
got a single piston one myself - had to use it with my old sidedraught turbo setup as sudden boost spikes when letting off caused the float bowls to dump fuel and run overly rich which caused a bog when nailing the accelerator again
dunno if im gonna fit it on me EFI Gotech T34 , havent really got space as im using the std xr3 rad with a FMIC , piping is tight
they are fitted by manufacturers to stop the map sensor seing boost spikes and dumping juice which will affect oxy readings during inspections and use extra juice
also useful for letting wankers in their hot na hatches know to piss right off!!!
#53
Originally Posted by Oranoco
Rubbish. A bloke down the pub told me they protect the turbo and give you 30bhp more. It must be true as he has a Saxo.
In all honesty DV's are an aquired thing like marmite, you either like the sound and have one, or you dont like the sound and dont have one.
This topic gets very heated every time it's brough up doesn't it!!!
Lee
#55
st170 breaking
Originally Posted by Turbocabbie
Yes I am aware that many vehicles including the Focus RS have recirculation type valves as they require them for the type of turbo they have, but as stated Ford never fitted them to the MFI RST as they were not and are not needed
hardly fair in 2 instances,
1: 8psi isnt going to do much whatever happens most of us run 15-20
2: erst's were early days for this lark, if it was built now it would have 1 (as new turbo cars generally do-frs) doesnt mean it dont need 1, ersts need lots of things that wernt fitted as std, technology moves on and we look back and say, wish i knew then what i know now
#58
st170 breaking
Originally Posted by T28 RST
If all RST's need them why are so many running without one
just cant say that if it wernt fitted as std its not to be fitted because its unnessecary
#60
#62
I have some cheap twin piston DV and only bad thing about them are bangs from exhaust, because air get out of inlet mainfold. dont know if this afecting driving, power... idle is same as before, driving is same. I dont measure times so dont know is there any looses or gains. It would be great to make some little test of DV on few RST, measure 0-60 with and without DV...
#63
Well for what my 10 years of RST ownership is worth.......dump valves are for Gays,end off.I ran 19 PSI boost for many's a year making much more powerfull cars look very silly,and never once ran a DV.Car was set up by Mark Shead,who knows a bit about RST's and he told me that running a dumpvavle was a waste of money and effort!!So if you're 19 yrs old,think you know it all,then go ahead,use a DV....Regards,Micky
#64
well how comes everyother rs is see i hear a dump valve.
and that is bollax, why is it gay having a dump valve or a chav. every1 is a chav then because u own an escort rs. dnt agree with that atall. i actually like the sound of my baileys dump valve.
why dont you get a CHATTER. tbh i dnt know wether u can but my mate has one on hes frst and it sounds the nuts
#65
#66
It's not really bitching mate. If you like the noise and want one then get one, just don't expect any of the so called turbo serving benefits that they are supposed to offer
#67
#70
Originally Posted by S2Steve
Don't use one, why would you want one, there is no need and turbo chatter sounds a lot nicer
how much can u get a chatter for
#71
No you can't buy a chatter as so many of you put it just remove the dump valve and you will hear it end of,
Yes it still does it on mfi and some do it louder than others depending on boost level you are running.
HTH
#72
#74
hey guys, what does CHATTER mean ? i took my dv off for around a month when i was boooting it it sounded like it was dumpin still,its this called chatter ?? cheers haha
#75
Here's a Escort chattering away
http://www.youtube.com/watch?v=PIlpxLw6gYg
#76
#77
all t series turbo apart from the t4 they dont produce enough back pressure to need a dump valve but they are a must on gt series turbos, the chatter is the air the engine does'nt consume getting cut up by the turbo blades.
sean
sean
#78
Here's another Fiesta chattering away.
http://www.youtube.com/watch?v=baUEBAKw5vQ
http://www.youtube.com/watch?v=ts6_Z...eature=related
#79
has anyone ever thought about fitting a recirculating valve to an rs turbo?
It could be piped back to the pipe between the turbo and the metering head (the suction side of things)............ there must be a reason why i have never seen it done.
also by not running a dump valve are you not more likely to bend your metering head when the back pressure occurs......or is it far enough away for the air not to be turbulent in the metering head? and have I just answered my own question about the recirculating valve?
#80
not a case of people thinking about doing it as more a case of it's a waste of time. people only fit dump valves to stamdard rst's cos they think it sounds cool. why would the same person fit a recirc that won't make the ppttsshh sound that they want. it won't make the car more reliable or better to drive. thats propbably why it hasn't been seen.
