s2 problem
Old Aug 1, 2007 | 06:58 PM
Dave Parker's Avatar
Dave Parker
Default s2 problem
anyone know why throttle is stuck at 4000 rpm not cable or butterfly
help please
Old Aug 1, 2007 | 07:20 PM
gup's Avatar
gup
have you checked your auxillary valve fella as this could be stuck open causing the high revving
also is the throttle cable pushed back to the stop
Old Aug 1, 2007 | 07:21 PM
gup's Avatar
gup
also have you screwed your base idle scre in by the right side of the throttle body with the spring on it
Old Aug 1, 2007 | 07:27 PM
Dave Parker
cable and throttle are back at the stop i have not touched the base idle screw how do i check auxillary valve
cheers
Old Aug 1, 2007 | 07:33 PM
gup's Avatar
gup
if you take the 2 hard plastic pipes off from the valve under the inlet and shine a torch through it to see how open it is if that makes sense or you could just take it off and look in it lol
have you checked the pipes going to the amal valve to see if any have popped off
Old Aug 1, 2007 | 07:39 PM
Dave Parker
should it be open if so how much pipes are on amal
cheers
Old Aug 1, 2007 | 07:43 PM
gup's Avatar
gup
if im right then when the engine is hot then the valve should be comletely closed and when it cold it should be open
Old Aug 1, 2007 | 08:14 PM
jayjay's Avatar
jayjay
3 pipes mate on the amel valve
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
