FAO people with rear disc conversions
Old 31-07-2007 | 07:22 PM
GraphiteGray's Avatar
GraphiteGray
Default FAO people with rear disc conversions
How you use push the cylinder back into the caliper on the rear discs? (2WD cossie)
One of my calipers was making an awful rubbing noise so i took it off the hub (guessed siezed caliper) and carefully pumped out the cylinder as far as i dared to clean it (so it didnt pop out and leak fluid), but it wouldnt push back in, even with a huge pair of stilsons
It seems to turn easily in the caliper though and by turning it clockwise its starting to receed into the caliper, so should I be winding it in or pushing it in?
Need to get the car back on the road for work tomorrow
HELP
Old 31-07-2007 | 07:30 PM
Rick's Avatar
Rick
you need a caliper piston retractor.
Old 31-07-2007 | 07:36 PM
JesseT's Avatar
JesseT
push and turn simultaneously.
Old 31-07-2007 | 08:01 PM
mercury grey minter's Avatar
mercury grey minter
As above,it screws back in. You need a retracting tool or you can just turn it with pliers.
Old 31-07-2007 | 08:39 PM
GraphiteGray
Cheers guys, i managed to screw it back in with a balljoint splitter (prongs fitted perfect in the slots), think im gonna have to invest in a proper piston retractor though
What i dont get is when you pump the pedal it pushes straight out without turning or anything, so why does it have to be screwed back in?
Old 31-07-2007 | 10:58 PM
SafeChav's Avatar
SafeChav
You silly twat
The piston is on a threaded shaft, its to do with auto adjustment on the handbrake side, so as the pads wear the piston auto adjusts, so the handbrake travel doesn't increase
YODI
30-08-2015 01:12 PM
RsS2daz
14-08-2015 05:26 AM
track.focus'd
12-08-2015 05:53 PM
Graceland
31-07-2015 10:34 AM
Quick Reply: FAO people with rear disc conversions
