help speedo jumping!
hi guys, just wonderd if any 1 can help? my speedo jumps on my rs turbo van (s2 lump) with lsd box, ive tried a mates speedo head, new cable and even the plastic drive in the box with no joy, ive got a 1600 diesel box spare but if i use this do i have to swap plasic drive from lsd box 4 speedo 2 work correct?
st170 breaking
if you use a diesel box you'll find it will have a better top end but lose lower down
but it can also mean you'll get to 60 in 2nd rather than having to change to 3rd
(or thereabouts)
(or thereabouts)
st170 breaking
lsd if you can find 1
not sayin a diesel box is bad, can be better, means a higher 1st gear too which is better all round
i have a diesel box with a lsd fitted was in the car very short while before stripping but more drivable
ok mate thanks, its hard to no wot box to use, as i say only looking to cange it as my speedo no workin correct, so mite put the diesel one in while get lsd rebuilt, i think its personal choice as sum peeps like diesel box n sum dont, do u still have that mk4 estate from ur pic?
dont use a 3i box mate, i tryed that. big mistake, gearing is so wrong for an rs, i was flat out at 110. got a dieasle box on it now, nice big gaps between changeing gear now, no lsd but next best thing to the proper box!!
