amal valve pipe
ok probably a stupid question but does anybody know
what the pipe from the amal valve to the metering head
actually does and if it needs this pipe for any reason.
i am asking because my car has 2 bleed valves fitted,
one is replacing the amal valve so is just working as a t-piece
basically and the other is doing its job but i would like
to do away with both of them and just run the pipe straight
from the actuator to the turbo.
thanks
thanks
ok thanks, so i could do away with the bleed valves,
block off the one to the metering head and
just pipe actuator straight to turbo?
07-10-2015 12:56 PM
