quick question, Help!!!
Old Jun 1, 2007 | 03:46 PM
dee00's Avatar
dee00
Default quick question, Help!!!
hi guys, just wanted to find out what can be leading to this problem. Basically When i turn my steering to full lock and move, somthing near the wheels clicks and grinds very bad and its constent untill i straighten the steering wheel, i was thinking wheel bearings but i can be wrong. It also makes a slight grinding noise when driving normally now, seems to have gotten worse. It doesnt allow the car to move well when on full lock, also the breaking feels abit diffrent.
Cheers guys
Old Jun 1, 2007 | 04:11 PM
gaz s1's Avatar
gaz s1
sounds like a cv joint is fucked mate or as you say could be a bearing
Old Jun 1, 2007 | 04:51 PM
djmillsy's Avatar
djmillsy
Fife Radge
same as above
Old Jun 1, 2007 | 09:52 PM
dee00's Avatar
dee00
if its not the CV joint or bearing, what else could it be? Anything else i should look out for?
Old Jun 1, 2007 | 10:17 PM
djmillsy's Avatar
djmillsy
Fife Radge
lose parts ifs it rocks side to side its the bearing and up and down its the cv joint
Old Jun 1, 2007 | 10:26 PM
dee00's Avatar
dee00
if what rocks? and why does my breaks feel diffrent?
Old Jun 1, 2007 | 10:29 PM
djmillsy's Avatar
djmillsy
Fife Radge
the wheels how do the brakes feel different
Old Jun 1, 2007 | 10:33 PM
dee00's Avatar
dee00
when i push the pedal seems to gradually feel harder. im going to change the front two wheel bearings tomorow, hopefully it should sort the problem. If the CV joints were fooked wouldnt i be able to see if im right they normally let out that black greece
Old Jun 1, 2007 | 10:38 PM
djmillsy's Avatar
djmillsy
Fife Radge
some times if you jack the car up an put a bar under the wheel and move it up and down and you get play then th cv joint is shagged
what kinda car is it
Old Jun 1, 2007 | 10:42 PM
dee00's Avatar
dee00
s2 erst, well basically i got the wheel bearings, so ill change them tomorow. Ill push the wheel up and down to cheak if the CV joints are okay (fingers crossed). But when i reverse on full lock or go forward it clicks/nocks just as bad as it grinds.
Old Jun 1, 2007 | 10:49 PM
djmillsy's Avatar
djmillsy
Fife Radge
sounds like cv joints mate or maybe a spring does the abs still work and are the brakees still working fine
Old Jun 1, 2007 | 10:51 PM
dee00's Avatar
dee00
well as i said the pedal seems to have stiffend, to be honest i have no clue so im gonna work from bearings onwards..............
Old Jun 1, 2007 | 10:58 PM
djmillsy's Avatar
djmillsy
Fife Radge
brakes and bearings srent linked if the cars still stopping fine then i wouldnt worry to much
Old Jun 1, 2007 | 11:00 PM
dee00's Avatar
dee00
yhea i know, well ill see how it goes tomorow, cheers for the help mate ill let you know how i got on
Old Jun 1, 2007 | 11:11 PM
djmillsy's Avatar
djmillsy
Fife Radge
nae bother good luck you just have t eliminate things check you arches for the wheels rubbing
Old Jun 1, 2007 | 11:52 PM
dee00's Avatar
dee00
they definatly aint rubbing, my cars only been lowerd 30mm, but yhea cheers.
Old Jun 2, 2007 | 07:04 PM
dee00's Avatar
dee00
sorted, my disk was scraping my calliper my pads were too worn and some twat took a spacer off, which led to my calliper scraping my disk.
Old Jun 2, 2007 | 08:24 PM
djmillsy's Avatar
djmillsy
Fife Radge
good to hear mate some people are just idiots
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
