Actuator Split Pin
If you can't get one and your Wastegate pin has a hole through it, just put a thin Paper-Clip or piece of wire through there. As long as it stops the arm coming off, it will be fine.
Originally Posted by JesseT
Never actually had anything there on any of my cars. If the actuator rod comes off, either the preload is wrong or the actuator is pointing to the wrong direction.
You jammy sod
Mine had the original circlip that turned into a pile of brown powder.
Originally replaced it with a furniture staple, which worked well, then replaced it with a shiny R-pin just so it looked a bit less bodged
muz
Sep 30, 2015 08:29 AM
