brake problem
Old Apr 20, 2007 | 09:25 AM
Maxxeh's Avatar
Maxxeh
Default brake problem
Hi, we took the abs properly and now the pedel has no feel to it at all. the pedal only gets a little bit stiff if i pump it. wat cud it be? the car is too dangerous to drive.
Old Apr 20, 2007 | 10:51 AM
Marc LJX's Avatar
Marc LJX
Do you mean you took the ABS off properly?
If so then i assume you have bled the brakes at all 4 corners?
Obviously there will be air in the pipes where you did the joints, and this needs to come out...
Are you sure you bled the rears ok? (With regards to the load compensators)
Old Apr 20, 2007 | 03:40 PM
addiction's Avatar
addiction
as above mate.
have you bled the brakes properly??
Old Apr 21, 2007 | 12:19 AM
SafeChav's Avatar
SafeChav
Air in the system as above
Old Apr 21, 2007 | 08:05 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
suck the fluid trough each side with a pump,you can buy from most motor factors,this will pull the air through,and yes ,make sure your load compensators are free from debris and close fully (no gravel wedged in there) and bleed the rears fully loaded,with the car weight on the tyres,car level as normal driving per se,awkward without a ramp, but it has to be done this way.
Old Apr 23, 2007 | 05:18 PM
escrst's Avatar
escrst
the brakes on an escort rs turbo will feel spongy unless you bleed them in the right order. its passanger side rear drivers side front, drivers side rear passanger side front. if that dont work you havent joined the pipes right when the abs has been removed.
Old Apr 23, 2007 | 06:49 PM
addiction's Avatar
addiction
just removed the abs off mine and done a rear disk conversion.
when i bled the system i did driver side rear, then passenger side rear, then driver side front , then lastly passenger side front!
you should allways start with the furthest away from the master cylinder then work to the front.
my brake pedal is now superb and thats with a rear disk conversion too
Old Apr 24, 2007 | 07:31 AM
escrst's Avatar
escrst
get a haynes manual it tells you in there!
Old Apr 24, 2007 | 08:23 AM
Maxxeh's Avatar
Maxxeh
just bought a new brake servo and master cylinder which sorted the job.
my brakes actually work now
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
