Exhaust Manifold / Turbo
Just wondering what turbo's can actually be fitted to the ERST exhaust manifold?
I see things like ".60 A/R Compressor" and ".63 Compressor"
Also I see statements like "Internal Wastegate set at 12 Psi ", are they referring to the actuator? If I wanted to run more boost I would simply replace the actuator ?
Thanks for any help.
ok minimal lag if u want to be perdantic about it
1st turbo was at full boost 2k earlier than a T34 so why is that not suitable for any engine spec if u want resonable power
Originally Posted by stuart collins
custom built gt25/30, made 2 bar of boost by 2.8k on my engine which runs a really wild cam so it would be even better on different cam
I suppose I could re-phrase what I said, and put it into a question...
Will any old turbo fit the ERST exhaust manifold, or is it dependant on the A/R Compressor etc... ?
For example, could I fit a GT28 with a .60 A/R compressor to the ERST manifold?
Thanks.
Thanks.
Originally Posted by Rick
Stuart - graphs please
there u go shows u nothin
it looks like the first 1 has loads of lag when in fact it was so much more responsive drove better and was so much faster
and the second 1 is with a t34 on and was crap boost a 4k
if it was still together i would let u drive it and u would no wat i mean
#1 in Spelling Club
Stuart, without wanting to sound picky, neither of those graphs show anything that is unexpected. Both are laggy turbo's and both show that on the graph.
My GT28 (which is known in the Jap world as the 'Disco Potato', due to it's fast response) wasn't on boost that early.
My GT30 doesn't make full boost until after 4000rpm, even later with the bigger turbine housing.
The same turbo on a 200SX 2.0 16v engine isn't much different, so why should a turbo like that have 2-bar at 2800rpm on a tiny 1600cc engine??
rsstav
Ford Focus RS Parts for Sale.
20-08-2015 07:45 AM
