electronic boost controllers
Old Mar 6, 2007 | 11:29 AM
Maxxeh's Avatar
Maxxeh
Default electronic boost controllers
Am i right in thinking that when changing boost with an electronic boost controller, will it not mess with fueling when u change boost settings?
ive always thought having one of these but dont kno which is the best one to use on MFI. i like the controllers becoz they hold boost better.
Old Mar 7, 2007 | 01:24 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Yes, all a boost controller will do is allow you to adjust the boost pressure, usually a percentage of actuator pressure. It will not alter the fuel settings what so ever.
Old Mar 7, 2007 | 01:26 PM
Maxxeh's Avatar
Maxxeh
theres no point of buying a apexi for my mfi is there?
Old Mar 7, 2007 | 01:31 PM
Tony Turbo's Avatar
Tony Turbo
I don't know much about Apexi stuff, are you talking about an AVC-R? I know that that can show things like injector duty which cannot be used with MFi.
The Apexi is a quite advanced boost controller, probably overkill for a standish RS Turbo. I'd recommend the Greddy Profec 2 Spec B, it is cheap and easy to work with. If all you want to do is adjust the boost while driving and have better boost stability then it is ideal.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
