adjusting boost
Old Jan 4, 2004 | 11:45 AM
Norton's Avatar
Norton
Default adjusting boost
before i had my car chipped and i had the old actuator, i used to be able to adjust the boost by adjusting the length of the rod on the actuator. Now i have had it chipped, the actuator looks a bit different, can i still adjust it in the same way by changing the length of the rod?
Old Jan 4, 2004 | 04:53 PM
Exeter J's Avatar
Exeter J
Yep - should be able to. Although it might throw your settings out, if you had it set up after being chipped.
Also it is possible that your new actuator is a changeable one. If it has allen key type screws you can open it up and get a stronger or weaker spring put in it. - But you need to the the type etc b4 you order a diff spring.
Old Jan 4, 2004 | 05:10 PM
stevo's Avatar
stevo
get a bleed valve and adjust it that way
Old Jan 4, 2004 | 08:58 PM
yeah i agree wiv stevo that what i av
Old Jan 6, 2004 | 09:18 PM
Norton's Avatar
Norton
where should i get a bleed valve from? are they expensive? hard to fit?
cheers
Old Jan 6, 2004 | 10:05 PM
not expensive at all piece of piss to fit
Old Jan 7, 2004 | 06:53 AM
adamS2RST's Avatar
adamS2RST
Dont get a bleed valve!
Old Jan 7, 2004 | 07:27 PM
Exeter J's Avatar
Exeter J
I'd agree - Problem with a bleed valve is that you get bored with the boost your running and turn it up a bit more every now and again Then pop - well thats wot I did
Old Jan 7, 2004 | 10:10 PM
Norton's Avatar
Norton
i got one set of people sayin get a bleed valve and another set of people sayin dont!!
Old Jan 7, 2004 | 10:19 PM
adamS2RST's Avatar
adamS2RST
Norton - It's upto you mate, But as Jamie says you can get bored of boost and just whack it up, next thing u know, bang. Just dont like em IMO. U could get one that is fixed though, but again if u want more boost you will just wind it out and bang!
Old Jan 7, 2004 | 10:43 PM
wots the lowest boost you can run???
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Fezman1
Oct 2, 2015 01:22 PM
Russ Payne
Sep 25, 2015 08:29 PM
