EFI problem
Old Jan 21, 2007 | 04:23 PM
Bakster's Avatar
Bakster
Default EFI problem
I have no problem starting up a cold engine and everything is fine. But when the engine warms up sth happens - when pushing gas engine dies and seems like no power is transferred. What may be the problem: CPS? idle engine? Coolant Temperature Sensor? 3-bar MapSensor?
Old Jan 21, 2007 | 04:33 PM
davsmith64's Avatar
davsmith64
sounds like u have a fuelling problem,, has it been rolling road setup since u converted it?
whats boost is it running? also u may have a air leak somewhere!
Old Jan 21, 2007 | 04:36 PM
davsmith64's Avatar
davsmith64
haaaa, u say u have a 3 bar map sensor!! has the ecu been mapped to run this?
so when u say 3 bar map sensor, u have a OFAB setup! has the ecu been mapped to run a 3 bar? cos standard should run a 2bar ithink, or maybe its a 2.5, but deffo not 3 bar...
i had problem with mine when i first converted, it would start, but wouldnt rev properly! it was the ECU that was faulty..
has it got a Map Supressor in the loom?
Old Jan 21, 2007 | 04:38 PM
Bakster's Avatar
Bakster
I don;t mapped evu for 3 bar map sensor I don;t have supressor becouse I can;t buy him
Old Jan 21, 2007 | 04:47 PM
davsmith64's Avatar
davsmith64
no supressor
not been mapped for the 3 bar
people say that you can run it without the supressor but if u ask me its not there for no reason,
it could be either of those 2 mate,
dont think it will be you ISCV..
ithink you may be better talking to safechav about this mate..
has it been setup since u converted? as when i first converted to EFI it ran mega rich the co2 level where at 10.5% and really they need to be around the 2.5 areaish
Old Jan 21, 2007 | 10:16 PM
Bakster's Avatar
Bakster
Maybe somebody know what is supressor ford number i catalog or maybe have some photos of this becouse I don;t know what have I to buy
Old Jan 22, 2007 | 09:36 AM
Bakster's Avatar
Bakster
maybe somebody have some photos of supressor or his ford serial number
Old Jan 22, 2007 | 02:04 PM
davsmith64's Avatar
davsmith64
all the supressor is, is a small square component with a few wires to it..
Old Jan 22, 2007 | 03:44 PM
davidnormanuk's Avatar
davidnormanuk
It's worth noting, that these supressors are no longer available from Ford, and when they were available, they were Ł100 odd!
However, if you need one, speak to Kenny at http://www.motorsport-developments.co.uk/ He will be able to supply you one new for Ł50, delivered.
This is taken from http://www.rsbible.co.uk/
Bakster's Avatar
Bakster
Is it a serial parts?? becouse in Poland ford service the don;t know what supressor mean and they ask me for a serial number or number in motorcraft catalog
Old Jan 22, 2007 | 03:55 PM
davidnormanuk
It'll have a part number on it. I have one at home I can check for you later on.
Old Jan 22, 2007 | 04:51 PM
SafeChav's Avatar
SafeChav
The suppressor shouldn't be an issue, that was a revision to later cars, certainly wouldn't go a miss though.
But, i agree...........3 bar MAP and no chip
Old Jan 22, 2007 | 10:05 PM
Bakster's Avatar
Bakster
Just few minutes ago I put my ecu to a company whey will make mapped for 3 bar map and then I will see how the car will running
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
dms04
Sep 11, 2015 01:57 PM
